Dodge Stealth R/T Issue
#1152875
01/08/12 03:24 PM
01/08/12 03:24 PM
Posts: 147 Pittsburgh,Pa
Dads70RTConv
Pittsburgh,Pa
Have a Stealth r/t twin turbo ....whenever it gets cold out the inside STINKS of raw gas ....and yet theres no smell outside and no visible leaks anywhere .......anyone have any clues as to what it could possibly be?
Miss ya Dad
3-31-55
9-21-10
70 Coronet R/T Convertible
Re: Dodge Stealth R/T Issue
[Re: Pacnorthcuda]
#1152877
01/08/12 08:31 PM
01/08/12 08:31 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Most likely the seal that seals the tank and fuel pump assembly. However the lines from the assembly are known to rust also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1152878
01/10/12 12:50 AM
01/10/12 12:50 AM
Dads70RTConv
Pittsburgh,Pa
went and moved it today and the fuel pressure regulator was leaking so thats one problem still gonna check the tank etc to make sure
Miss ya Dad
3-31-55
9-21-10
[Re: Dads70RTConv]
#1152880
01/10/12 04:52 PM
01/10/12 04:52 PM
Silver70
Rust Belt, SW PA
They have injector o-rings to the rails and a seal on the intake that goes around the injector bottom. You can see the front ones, so look for cracks as after 20 years on a turbo engine, they see heat and my engine they were all cracked. For a few bucks per injector and a couple hours, it might not be a bad idea to replace those too and the other rail o-rings, then you'll know it's all sealed up.
