What type of heads where on 1970 Abody 340
#115249
09/04/08 08:15 PM
09/04/08 08:15 PM
Posts: 122 Huntertown, IN U.S.A
abodyfan
I was wondering what type of heads where supposed to be on my 1970 340 Duster. It has a 1972 340 block in it and the heads don't have any markings that I can tell if they are correct for the car or the engine. I am looking for a date coded block and was wondering if I should look for heads also.
1971 Dodge Demon 340 4-speed
1970 Plymouth Duster FM3 340 727
1968 Dodge Dart GT Convertible
Re: What type of heads where on 1970 Abody 340
[Re: RobX4406]
#115252
09/04/08 09:12 PM
09/04/08 09:12 PM
abodyfan
Where are the numbers located on the heads. There is ton of paint on the engine. My Demon has J heads on it. I was figuring that the Duster should have x heads on it. There isn't any letters on the head of the 70. Could this mean they are 72 heads on the 72 block.
[Re: RobX4406]
#115254
09/04/08 09:29 PM
09/04/08 09:29 PM
abodyfan
I don't recall where the casting numbers are supposed to be located. Sorry my memory isn't what it used to be.
[Re: abodyfan]
#115255
09/04/08 09:46 PM
09/04/08 09:46 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
Between the spark plugs.Now that i think of it the j is cast backwards.
[Re: MoparforLife]
#115258
09/05/08 08:28 AM
09/05/08 08:28 AM
Posts: 4,799 ILL
MLR426
ILL
On some you have to pull the head to see the casting numbers that are cast in the valley side of the head in the area of the exhaust crossover. Even if they are 72 heads don't sweat it. The only difference would be teh 1.88 intake valves and you will more than likely be better off with them any way as they will most times offer you more low end than the 2.02 valves will which come more into play at RPM's over 6000 or so.
You are correct with stock cams, but if 2.02 heads are used with a proper cam to support the larger valve and pocket size you have more power and the low end will be there.
logan426
