LA engine memory check #1152437
01/07/12 08:14 PM
01/07/12 08:14 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
So do I remember correctly that the front and rear exhaust manifold bolts are the only ones into the water jacket?
Thanks,
Mike
Re: LA engine memory check [Re: 1E2C] #1152438
01/07/12 08:14 PM
01/07/12 08:14 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
yes
Re: LA engine memory check [Re: 1Fast340] #1152439
01/07/12 08:37 PM
01/07/12 08:37 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Well alrighty then, I'm not totally senile yet, that part at least is good to know.......
Thanks again
