Page 3 of 5 1 2 3 4 5
Re: Why so much hatred for the KYBs? [Re: jcc] #1152042
01/15/12 09:07 PM
01/15/12 09:07 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I put a set of kyb's on my Cop Dippy about 15 years ago, my brother now uses the car for a winter beater. I was in it last week and have to say that they are just starting to work good, they just needed 200 thousand break in miles.
A new iron curtain drawn across the 49th parallel
Re: Why so much hatred for the KYBs? [Re: jcc] #1152043
01/15/12 10:03 PM
01/15/12 10:03 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What about the custom ones by XV? Are they in the same class as King? Are theyway above the KYB's? Does anyone have real world experience with them?
Re: Why so much hatred for the KYBs? [Re: TC@HP2] #1152044
01/15/12 11:28 PM
01/15/12 11:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Understanding the difference between progressive, digressive, and linear valving combined with road conditions and the ever present "driver capability" variable goes a long way in understanding why some shocks feel overly soft while others feel too stiff. Suffice it to say there are so many variables at play that, like a broken clock is correct twice a day, so too can even a piece of junk like a KYB can work well on some combinations, in some environments, with some drivers.
In any case, to understand appplication of shock dynamics and capability is a big reason why so many Cup cars are so fast while others are also ran. Two decades ago there was no such things as a shock engineer and nobody bothered to dyno their shocks. These days, if you want to be a front runner, these are important things to have if you ever want to win. The understanding and capability of a shock is of paramount importance to the overall suspension operation.
Lets put it in these terms; shock absorbers are to a suspension what a camshaft is to an engine. Much like a cam will determine an engines useful range, power levels, ranges of power, and curve of power, so too will a shock operation within a suspension system to determine operating characteristics, manners, and feel. Matching shocks to suspensions achieves results similar to matching cams to engines. Sure any old thing thrown in there will work, but when you seek to achieve optimal results, the cheapest shocks with the most pressure are not going to be any better than using the cam with biggest lift and longest duration.
Nowdays Cup teams have Shock Departments. Not just one engineer.
Heck we have a shock dyno for our local circle track team car. We have about 10 shocks per car to mess with.
Re: Why so much hatred for the KYBs? [Re: autoxcuda] #1152045
01/15/12 11:46 PM
01/15/12 11:46 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Part of shock Dyno sheets...Force vs. Stroke graph
Re: Why so much hatred for the KYBs? [Re: autoxcuda] #1152046
01/16/12 12:03 AM
01/16/12 12:03 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ive plenty of experience with Kings. I prefer them over Fox's personally.
Mopar to the bone!!!
Re: Why so much hatred for the KYBs? [Re: JoesMopar] #1152047
01/16/12 12:07 PM
01/16/12 12:07 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
To me....they suck. They're way too harsh for my liking. I had a set just recently (that were still good) on a police package Diplomat and the car rode like absolute crap. I could fell every bump in the road like the car was going to fall apart. The handling was worse than it should have been as well. Because if I took a corner at higher speed than the speed limit and I happened to hit a "bump" the car would literally "skip" in the turn. I'm amazed I haven't wrecked it. I went to the Monroe Sensa-Track or whatever they're called and the car is 10X's better.
my experiences with my hot rodded 5th ave that has police spec rear springs and sway bars...were very harsh on minor road imperfections, also felt a little underdamped with my heavy wheel/tire combo (17x8 mustang rims and 255/50R17's)....switched to monroe sensa tracks and lost none of the handling ability, but ride improved substantially.
2017 Grand Cherokee Overland
Re: Why so much hatred for the KYBs? [Re: patrick] #1152048
01/16/12 12:22 PM
01/16/12 12:22 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I have KYB's on the front and Monroe's on the rear of my 80 Mirada and have the same problem. The front is way too stiff, and some bumps can really upset the car in a turn. I have HD leafs in the rear but even so you can really notice the difference between the 2 shocks as the front and then back wheels hit a bump or pot hole.
Re: Why so much hatred for the KYBs? [Re: 440newport] #1152049
01/16/12 02:22 PM
01/16/12 02:22 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Not a hater...I had KYB-s on the R/T for over 10 years, for the cost then of a bit above other current slightly over stock performance shocks I thought they were ok.
Since the QA1 double adjust I never looked back...but its two sep. worlds.
For my use I dont think I will need a better shock.
Thinking back to the days of the street race junk, kyb-s or the better bilstein?? shock was the ticket.
Re: Why so much hatred for the KYBs? [Re: A57_RT ] #1152050
01/16/12 08:31 PM
01/16/12 08:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Back in the early 90's when I was setting up my frist A body I called KYB and got the shock rate info from an engineer there. He wanted to know why I wanted it and when I explained what I was doing he had no problem helping me out.
Your shock rate has to be compatible with your wheel rate. Since I could not afford expensive shocks I was stuck with KYB's. So I built my suspension around the shock rate available to me. I have no complaints with how it rides or how it handles. If I had the money I would probably got about it differently, maybe.
Don't be the exception.
Re: Why so much hatred for the KYBs? [Re: Supercuda] #1152051
01/16/12 08:47 PM
01/16/12 08:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You gotta run what you can afford.
Do you remember what rates and specs he gave you for those KYB's.
I ran them for years on my Barracuda with .99" T-bars and I blew a few out. To the point when I jacked the car they just bled shock oil out. I think I was at the limit of the spring rate for those shocks.
I know people that have ran KYB with 1.06 or higher T-bars and the ride is real wacky. They are overcome by the spring rate.
Re: Why so much hatred for the KYBs? [Re: autoxcuda] #1152052
01/16/12 09:32 PM
01/16/12 09:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To be honest, I might have my setup notes somewhere, but I couldn't tell you where. I do remember I ran the .89" bars with an 1 1/4" front sway bar. In the rear I believe I ran 160 lbs/in rate leafs and a 3/4" rear sway bar. Nothing too wild. Plus the widest tires I could fit, I believe they were P245/60R14's in the rear, with a rolled lip and the inner sidewall would just smooch the leaf in spirited driving. Fronts, I think were P225/60R14's. All in a 72 Swinger.
Re: Why so much hatred for the KYBs? [Re: Sinitro] #1152053
01/24/12 11:41 AM
01/24/12 11:41 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The best shock absorbers are made by Bilstein and Koni..
Not cheap but they work great and last 100K miles..
Just my $0.02..
I second that emotion. Funny thing, I read all of the above, and my complaint with KYBs is the exact opposite: Not nearly firm / stuff enough!
I've used Konis (eventually) on every car I've ever raced. Always like "yeah, now we're talkin'" when I finally bite the bullet. And the almost infinite adjustability is awesome.
Used Bilsteins on a 1G Dak recently, quite impressive, too.
Rick
Re: Why so much hatred for the KYBs? [Re: Rick_Ehrenberg] #1805931
04/17/15 10:59 PM
04/17/15 10:59 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Since old threads sometimes dredge up info that may be helpful to new members, I thought I'd dig this topic up.
I still have the KYBs in my Charger, but have ordered a set of Bilstiens from Firm Feel. I also have a pair of 1.15" torsion bars coming from Bergman Auto Craft. I will give staus reports after the installation and a little street time.
Re: Why so much hatred for the KYBs? [Re: Kern Dog] #1807596
04/20/15 11:10 AM
04/20/15 11:10 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I had KYB GR-2's on the front of my 73 Charger with 1.06" bars. Every crack in the road would be jarring and shake the whole car. I was thinking of going down a size in T-Bar because of it. Recently I put Koni Oranges on the front and its a completely different, smooth riding, good handling car. I am think of actually going up 2 sizes in T-bar because the shocks can actually control it.
Re: Why so much hatred for the KYBs? [Re: Kern Dog] #1807620
04/20/15 11:48 AM
04/20/15 11:48 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
KYBs use a high pressure nitrogen gas charge with divergent valving so they have a hard initial hit that softens as compression continues. So you get a jarring initial ride over small imperfections that feels like mush on sustained cornering.
Re: Why so much hatred for the KYBs? [Re: Kern Dog] #1808209
04/20/15 11:34 PM
04/20/15 11:34 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
KYBs porpoise when hot. They suck anyways.
AIS shocks suck too, they also porpoise when hot and are wayyyy too stiff. [Hint think about a porpoise does going thru the water]
Track tested, thumbs down for both.
Re: Why so much hatred for the KYBs? [Re: ThermoQuad] #1808262
04/21/15 12:43 AM
04/21/15 12:43 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This does make sense. I mentioned in another thread how my Charger will sometimes feel like the tail end feels as if it wants to step out, recovers, steps out a bit, etc when in hard turns. It makes the car feel unpredictable and twitchy.
Re: Why so much hatred for the KYBs? [Re: ThermoQuad] #1809248
04/22/15 09:57 AM
04/22/15 09:57 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Your bluntness is refreshing up
Re: Why so much hatred for the KYBs? [Re: Pacnorthcuda] #2977904
10/24/21 04:10 PM
10/24/21 04:10 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Coming up on 10 years and the truth is, KYBs still are a crappy shock absorber.
Re: Why so much hatred for the KYBs? [Re: Kern Dog] #2978040
10/24/21 10:45 PM
10/24/21 10:45 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
They ARE junk !!!!!!
