A12 Question #1151953
01/07/12 12:45 AM
01/07/12 12:45 AM
Texas
Ron69rr Offline OP
Ron69rr  Offline OP
Texas
Did the a12 come with a steel or forged crank motor?
Re: A12 Question [Re: Ron69rr] #1151954
01/07/12 12:48 AM
01/07/12 12:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
they are the same thing ... a forged crank is sometimes referred to as a steel crank ... aka chevy guys. Cast cranks didn't come about in any flavor 440 till 1973
Re: A12 Question [Re: JohnRR] #1151955
01/07/12 12:50 AM
01/07/12 12:50 AM
Texas
Ron69rr Offline OP
Ron69rr  Offline OP
Texas
I knew that I meant cast crank.
Re: A12 Question [Re: Ron69rr] #1151956
01/07/12 01:20 AM
01/07/12 01:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But that is not what you typed.
My mind reading skills are only good to 500 miles ... unless I have my tinfoil hat on , then it's 750 ...
Re: A12 Question [Re: JohnRR] #1151957
01/07/12 01:31 AM
01/07/12 01:31 AM
Texas
Ron69rr Offline OP
Ron69rr  Offline OP
Texas
I knew it but you didn't know I knew it. We use to say drop forged as they were stamped like a piece of sheet metal.
Re: A12 Question [Re: Ron69rr] #1151958
01/07/12 04:12 AM
01/07/12 04:12 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I was gunda say both......
Sheldon
Re: A12 Question [Re: Ron69rr] #1151959
01/07/12 09:55 AM
01/07/12 09:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
was your question answered ?
Re: A12 Question [Re: JohnRR] #1151960
01/07/12 12:28 PM
01/07/12 12:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just in case: Forged.
Re: A12 Question [Re: 6PakBee] #1151961
01/07/12 01:35 PM
01/07/12 01:35 PM
Texas
Ron69rr Offline OP
Ron69rr  Offline OP
Texas
Yes I got the answer I needed as I have always known they were forged cranks but thought only until 72. My buddy said they were cast and i said no way jose. It would grenade like a chinese fireworks display. Also the heavy duty 440 has forged cranks in them for quite a while after 73 like the ones in the motor homes.
Re: A12 Question [Re: Ron69rr] #1151962
01/07/12 07:45 PM
01/07/12 07:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yes It would grenade like a chinese fireworks display.
That I would find hard to believe,those Chevy guys make some pretty good horse power with cast cranks.
Re: A12 Question [Re: Ron69rr] #1151963
01/07/12 09:02 PM
01/07/12 09:02 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Jose's wrong.
Re: A12 Question [Re: 62maxwgn] #1151964
01/09/12 02:57 PM
01/09/12 02:57 PM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
Traitor!!
______________________________________________ http://regcars.homestead.com/car107.html
Re: A12 Question [Re: Alaska_A12] #1151965
01/09/12 04:14 PM
01/09/12 04:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Is this crankshaft list at the bottom of this link correct seems that it is?
http://www.fortunecity.com/silverstone/chrysler/45/bigblock.htm
MikeR
Re: A12 Question [Re: Alaska_A12] #1151966
01/09/12 05:53 PM
01/09/12 05:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Traitor!!
Truth hurts !!
Re: A12 Question [Re: 62maxwgn] #1151967
01/09/12 06:14 PM
01/09/12 06:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Mopar cast crankshafts - cast IRON or cast STEEL?
Re: A12 Question [Re: A12] #1151968
01/09/12 07:21 PM
01/09/12 07:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: A12 Question [Re: JohnRR] #1151969
01/09/12 08:57 PM
01/09/12 08:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Don't panic.....I thought that there are two types of "cast" crankshafts and the reason why "cast" gets a bad rap
Wouldn't this be like saying; I'm using "forged" connecting rods and not saying; I'm using forged "ALUMINUM" connecting rods. Everyone calls them CAST cranks.....cast what; iron or steel? So are there cast iron and cast steel crankshafts or is this another misnomer?????
Cast Iron vs Cast Steel
Firstly, let us know what is the cast iron and cast steel.
Cast iron usually refers to gray iron, ductile iron and malleable iron, which is iron casting with carbon content upper than 2%.
Cast steel usually refers to normal carbon steel and alloy steel, or called steel casting with carbon content lower than 2%.
Therefore, no big difference considering from the chemical content and raw materials for cast iron vs cast steel. However, their physical properties have many differences.
The advantage and disadvantage of cast iron.
The grey cast iron has good casting properties, good vibration damping, good wear resistance, good machinability and low notch sensitivity. However, its tensile strength and elongation are very low, so only can produce some metal parts with low physical requirements, such as protective cover, cover, oil pan, hand wheels, frame, floor, hammer, small handle, base, frame, box, knife, bed, bearing seat, table, wheels, cover, pump, valve, pipe, flywheel, motor blocks etc. As for the higher grades, grey cast iron can withstand greater load and a certain degree of tightness or corrosion resistance of the more important castings such as cylinder, gear, base, flywheels, bed, cylinder block, cylinder liner, piston, gear box, brake wheel, coupling Plate, medium pressure valve, etc
The ductile iron and malleable iron have high strength, ductility, heat-resistance and toughness, so a wider application, in some cases can replace the carbon steel. However, its production technology is high, production process is more complex, and production cost is higher than normal grey cast iron and cast steel, therefore, there are more casting defects for ductile iron. There are many fields that ductile iron are using for, such as Pressure pipes and fittings, Automotive applications, Agriculture, road and construction applications, General engineering applications.
The advantage and disadvantage of cast steel.
One of the advantages of cast steel is the design flexibility, the designer of the casting have the greatest freedom of design choices, especially the complex shape and hollow cross-section parts.
Cast steel has the metallurgy manufacturing flexibility and strongest variability, you can choose a different chemical composition and control, adapted to the various requirements of different projects. By different heat treatment choice in the larger context of the mechanical properties and performance, and good weldability and workability.
Cast steel is a kind of isotropic material and can be made into the overall structural strength steel castings, thereby improving the reliability of the project. Coupled with the design and weight the advantages of short delivery time, price and economy has a competitive advantage.
The weight range of steel castings is larger. Little weight can be only a few dozen grams of molten mold precision castings, and the weight of large steel castings up to several tons, dozens of tons or hundreds of tons.
Steel castings can be used for a variety of working conditions, and its mechanical properties superior to any other casting alloys, and a variety of high-alloy steel for special purposes. To withstand high tensile stress or dynamic load of components, it is important pressure vessel castings in low or high temperature by the large and important part load key parts, in principle, should give priority to steel castings.
However, the cast steel has comparatively bad shake-suction, wear resistance, mobility and the casting performance are compared bad with cast iron, moreover, the costs are higher than normal cast iron.
Therefore, for cast iron vs cast steel, they have their own advantages and disadvantages, you should choose it according to your application and their physical properties.
Re: A12 Question [Re: JohnRR] #1151970
01/09/12 11:09 PM
01/09/12 11:09 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
and 1500 miles if he uses TINFOIL toilet paper..
Re: A12 Question [Re: A12] #1151971
01/10/12 01:09 AM
01/10/12 01:09 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
There are cast iron and cast steel bell housings.
