Rear Center Unit #1151643
01/06/12 04:01 PM
01/06/12 04:01 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I have a 69 big block barracuda with an 8 3/4 rear end, I was wondering what sure grip center unit casting number this car should have. Thanks, Wolfe
Re: Rear Center Unit [Re: Wolfe440] #1151644
01/06/12 04:03 PM
01/06/12 04:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Probably a 741 but it could have a 489...
Re: Rear Center Unit [Re: 1_WILD_RT] #1151645
01/06/12 04:05 PM
01/06/12 04:05 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Which is the better one?
Re: Rear Center Unit [Re: 1_WILD_RT] #1151646
01/06/12 04:06 PM
01/06/12 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My 69 GTS 383 has a 489 .
Re: Rear Center Unit [Re: Wolfe440] #1151647
01/06/12 04:08 PM
01/06/12 04:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the 741 has a smaller pinion stem than the 489 , butthe 489 has a weak crush sleeve vs the stepped pinion shaft. Both pinions are smallest where the outer pinion bearing slides on .
It's a toss up ...
Re: Rear Center Unit [Re: JohnRR] #1151648
01/06/12 04:13 PM
01/06/12 04:13 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
I have a 657, I know it does not belong in this car, the yolk has a 1 1/8 u-joint. Will this yolk fit on a 741 or a 489? Or do both of those units come with a 1 1/8 u-joint also?
Re: Rear Center Unit [Re: Wolfe440] #1151649
01/06/12 06:24 PM
01/06/12 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
most 489's use a 29 spline yke , that 657 probably has a 10 spline , 741 can be either depending on when it was built .
Re: Rear Center Unit [Re: JohnRR] #1151650
01/06/12 07:14 PM
01/06/12 07:14 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Good info, I got to go hunting for a unit and I now know more of what I am looking for, Thanks for all the help!
Wolf..
Re: Rear Center Unit [Re: Wolfe440] #1151651
01/06/12 07:20 PM
01/06/12 07:20 PM
I believe the 741/742 have the same (very desireable) clutch sure grip unit itself which'll interchange w all 3 (including the 489 which OE has a cone sure grip). 4 diff pinion flanges 2&1/8 2&5/8 10 spline 29 spline
Re: Rear Center Unit [Re: Wolfe440] #1151652
01/06/12 07:32 PM
01/06/12 07:32 PM
Are you asking about the center section casting numbers or the posi unititself ? 1969 was the year that Mopar changed both, you could have a 721,742 or a 489 third member housing and you could have, depending on exactly when the car was assembled, either the Dana clutch type posi or the later GM style cup and cone type units
Re: Rear Center Unit [Re: RapidRobert] #1151653
01/07/12 12:26 AM
01/07/12 12:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
RR the 741 spanned both the 742 era and the 489 era , those made before 69 had the clutch type , those made 69 up were cone ...
Re: Rear Center Unit [Re: JohnRR] #1151654
01/07/12 01:49 AM
01/07/12 01:49 AM
Oh OK so the 741's had both. Didn't know that. Thank you double R
Re: Rear Center Unit [Re: RapidRobert] #1151655
01/07/12 04:28 PM
01/07/12 04:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Never seen a cone Suregrip in a 741.. Must do somemore JY hunting..
I am truckless..
