Re: Rear Center Unit
[Re: Wolfe440]
#1151644
01/06/12 04:03 PM
01/06/12 04:03 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Probably a 741 but it could have a 489...
[Re: Wolfe440]
#1151647
01/06/12 04:08 PM
01/06/12 04:08 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Which is the better one?
the 741 has a smaller pinion stem than the 489 , butthe 489 has a weak crush sleeve vs the stepped pinion shaft. Both pinions are smallest where the outer pinion bearing slides on .
It's a toss up ...
[Re: Wolfe440]
#1151649
01/06/12 06:24 PM
01/06/12 06:24 PM
JohnRR
I have a 657, I know it does not belong in this car, the yolk has a 1 1/8 u-joint. Will this yolk fit on a 741 or a 489? Or do both of those units come with a 1 1/8 u-joint also?
most 489's use a 29 spline yke , that 657 probably has a 10 spline , 741 can be either depending on when it was built .
[Re: Wolfe440]
#1151651
01/06/12 07:20 PM
01/06/12 07:20 PM
RapidRobert
I believe the 741/742 have the same (very desireable) clutch sure grip unit itself which'll interchange w all 3 (including the 489 which OE has a cone sure grip). 4 diff pinion flanges 2&1/8 2&5/8 10 spline 29 spline
[Re: Wolfe440]
#1151652
01/06/12 07:32 PM
01/06/12 07:32 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I have a 69 big block barracuda with an 8 3/4 rear end, I was wondering what sure grip center unit casting number this car should have. Thanks, Wolfe
Are you asking about the center section casting numbers or the posi unititself ? 1969 was the year that Mopar changed both, you could have a 721,742 or a 489 third member housing and you could have, depending on exactly when the car was assembled, either the Dana clutch type posi or the later GM style cup and cone type units
[Re: RapidRobert]
#1151653
01/07/12 12:26 AM
01/07/12 12:26 AM
JohnRR
RR the 741 spanned both the 742 era and the 489 era , those made before 69 had the clutch type , those made 69 up were cone ...
[Re: JohnRR]
#1151654
01/07/12 01:49 AM
01/07/12 01:49 AM
RapidRobert
Oh OK so the 741's had both. Didn't know that. Thank you double R
[Re: RapidRobert]
#1151655
01/07/12 04:28 PM
01/07/12 04:28 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Never seen a cone Suregrip in a 741.. Must do somemore JY hunting..
I am truckless..
