Re: Tips for 300M Headlight assembly replacement?
[Re: Gusteve]
#1151502
01/06/12 12:55 PM
01/06/12 12:55 PM
Posts: 19,991 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
It's just 2 bolts thru the top of the radiator support. The light will come right out IF you can get the bolts out. The bolts are often pre-destroyed and bent at the factory. You might have to get the bolts loosened as best you can, and then pry them out. We have to do it at work all of the time.
Earning every penny of that moderator paycheck.
DBAP
