68 and 69 roadrunner trunk lids different? #1151460
01/06/12 11:51 AM
01/06/12 11:51 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Are the 68 and 69 Roadrunner trunk lids different?
Ive seen some with a blind bracing and some other with an open bracing...
whats the deal?
Can a 69 have an blind bracing?
Re: 68 and 69 roadrunner trunk lids different? [Re: domingo] #1151461
01/06/12 12:01 PM
01/06/12 12:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They are totally different on the outside on the surface between the taillights ...
Re: 68 and 69 roadrunner trunk lids different? [Re: JohnRR] #1151462
01/06/12 12:28 PM
01/06/12 12:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, John, you are right.....I overlooked that and got confused when posting.....
Maybe my post should have been called "variations between 68 roadrunner trunk lids".
I am asking because I have 3 1968 lids at my shop.
2 of them have a bracing with large openings and you can see the sealer oozing from under the brace...
but 1 of them has a closed or blind underbrace.
I wonmder whats up with that? Is it an early/late production thing?
Re: 68 and 69 roadrunner trunk lids different? [Re: JohnRR] #1151463
01/06/12 12:32 PM
01/06/12 12:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's a '68 with the trunk finish panel but under it there is no oval depression for lack of a better term, it is basically flat with an horizontal line or crease...
Re: 68 and 69 roadrunner trunk lids different? [Re: A12] #1151464
01/06/12 12:41 PM
01/06/12 12:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A '69 RR trunk lid........the GTX and Satelite would have an oval finish panel in the depression..
I'm not sure if you could put a '68 trunk finish panel over the entire '69 trunk lid or not and get away with using it???????????????
Re: 68 and 69 roadrunner trunk lids different? [Re: A12] #1151465
01/06/12 12:49 PM
01/06/12 12:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
read my last poast above...i got confused when posting...i really meant something else...i forgot the lids were totally different between years!
Re: 68 and 69 roadrunner trunk lids different? [Re: domingo] #1151466
01/06/12 01:02 PM
01/06/12 01:02 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Oops I typed one and went looking for photos and answered a PM, hit send for the first one, typed the second and got a phone call and....well you know
MikeR
Re: 68 and 69 roadrunner trunk lids different? [Re: domingo] #1151467
01/06/12 03:21 PM
01/06/12 03:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can't answer that question , but it could be early vs late , I THINK a 69 lid is closed off underneath ...
Re: 68 and 69 roadrunner trunk lids different? [Re: JohnRR] #1151468
01/06/12 03:29 PM
01/06/12 03:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Don't know if the '68's had the same requirment for Federal Motor Vehicle Safety Standards (FMVSS) for "crumple zone" as the '69 trunk lids and hoods had????
http://a12mopar.com/yabb/YaBB.pl?num=1319412344
Re: 68 and 69 roadrunner trunk lids different? [Re: domingo] #1151469
01/07/12 03:17 PM
01/07/12 03:17 PM
NC
rc68rr Offline
rc68rr  Offline
NC
Are you talking about between the tail lites or on the under side of the trunk lid ?
Re: 68 and 69 roadrunner trunk lids different? [Re: rc68rr] #1151470
01/07/12 03:19 PM
01/07/12 03:19 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
68's rock!
Re: 68 and 69 roadrunner trunk lids different? [Re: rc68rr] #1151471
01/07/12 04:12 PM
01/07/12 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
underside
Re: 68 and 69 roadrunner trunk lids different? [Re: JohnRR] #1151472
01/07/12 08:04 PM
01/07/12 08:04 PM
NC
rc68rr Offline
rc68rr  Offline
NC
John this is our 68 RR it has a Nov 67 buil date.
Re: 68 and 69 roadrunner trunk lids different? [Re: rc68rr] #1151473
01/08/12 02:21 AM
01/08/12 02:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I haven't looked at the A12 thread link , but if you are 110% sure that is the original lid then I don't have an answer ...
Re: 68 and 69 roadrunner trunk lids different? [Re: JohnRR] #1151474
01/08/12 07:29 PM
01/08/12 07:29 PM
NC
rc68rr Offline
rc68rr  Offline
NC
John I am sure this is the orginal decklid.
Re: 68 and 69 roadrunner trunk lids different? [Re: rc68rr] #1151475
01/09/12 12:10 AM
01/09/12 12:10 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
1968 top image, 1969 bottom image
What are we looking for again?
MikeR
Re: 68 and 69 roadrunner trunk lids different? [Re: A12] #1151476
01/09/12 01:57 AM
01/09/12 01:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a Sep 30,'67 SPD car with the open areas in its inner panel; original to the car. IIRC, a couple of my other '68s had the same inner panel. All are St. Louis cars. This topic has come up before, and apparently there were 2 styles, possibly dependent on vendor or stamping facility, or maybe a running change.
