Re: INTAKE GASKETS FOR MCH CNC'D EDDY RPM'S???
[Re: BradH]
#1151314
01/06/12 05:09 PM
01/06/12 05:09 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used Superformance gaskets on mine
[Re: Sport440]
#1151318
01/06/12 10:28 PM
01/06/12 10:28 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Kind do what both Roadhazard and Sport440 do.
Port/file the pan, use a homemade paper gasket cutter for the gasket radiuses(radii?), knife for straight sections, and glue the paper/pan/paper sandwich together. Then do final clean-up with coarse grit tootsie roll.
Between this, and intake-gasket-head port aligning, I do end up with some time in it.
If you are just using paper, use a knife and/or tootsie roll. You use the pan siliconed to the under side of the head right?
[Re: Labratt]
#1151321
01/07/12 02:53 AM
01/07/12 02:53 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Randy, My heads dimentions are 2.50" x 1.22" My stock MP, "ported" vally plate is 2.50" x 1.30" I havent seen the Indy vally plate , but I bet you can opening it up with no problems, for what you need.
[Re: Labratt]
#1151328
01/08/12 03:39 PM
01/08/12 03:39 PM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Hello Randy and nice choice in head work...Jeff is tops. If your still looking for gasket advice just (glue with weatherstrip adhesive) on any old gasket. Set on them and cut the window to fit with a razor knife. 60% of the time ...it works all the time !!! Just clean/prep the surface with brakeclean before hand and work QUICK, the adhesive drys IN SECONDS!<<<Read the last sentence again. After glue cures apply to coats of your motor oil to the gasket surface so the gasket don't stick to the head/etc. and trim as req'd. Happy hunting. Sean
