Anyone use a remote oil filter?
#1151196
01/06/12 12:17 AM
01/06/12 12:17 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
I have one of these dual remote oil filters and I nned a new adapter plate for my external oil pickup. I am just wondering if I should use the milodon cover or some how adapt the dual oil filters
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Anyone use a remote oil filter?
[Re: rebel]
#1151200
01/06/12 01:18 AM
01/06/12 01:18 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Milodons kit 21525 shows a part you need to run that dual filter set up. I have a new cover with the adapter assembly to run 2 filters like you need. I run a remote with 1 filter. Here's the link to a milodon page to look at the parts. http://www.milodon.com/oil-system/chrysler.asp
[Re: Kam*Kuda]
#1151203
01/06/12 10:19 AM
01/06/12 10:19 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes use a cvr remote billet mount. Love it easier to change filter and now no oil in my collector.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Cab_Burge]
#1151206
01/06/12 09:48 PM
01/06/12 09:48 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If you do it to make the filter easier to reach, then yes, they are nice! if you do it to avoid spilling oil at oil change time, don't get one!
when I mounted mine, that was the first thing I thought, "hey, now I don't have to worry about trying to catch oil as it dribbles off the filter and all over the place" you know, how sometimes it streams straight down, other times it runs down the filter first, or a combo of both, then as you spin the filter off the rest of the way you get oil all over your hands...
but, even with it mounted "verticle" there's still oil "on top" of the filter that drains out when you remove the filter. if anything, THAT made a bigger mess than the stock location.
**Photobucket sucks**
[Re: rebel]
#1151207
01/06/12 11:40 PM
01/06/12 11:40 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Brand Fram Manufacturer's Part Number HP6 Part Type Oil Filters Product Line Fram HP Series Oil Filters Summit Racing Part Number FRM-HP6 Oil Filter Style Canister Height (in) 6.688 in. Outside Diameter (in) 4.625 in. Filter Bypass Relief Valve Yes Relief Valve Open (psi) 22 psi Anti-Drainback Valve No Smallest Particle Filtered 12 microns Maximum Burst Pressure (psi) 400 psi Thread Size 1 1/2-12 in. UNF-2B Gasket Outside Diameter (in) 4.250 in. Gasket Inside Diameter (in) 3.625 in. Gasket Thickness (in) 0.344 in. Quantity Sold individually. Please note,BYPASS OPENS @ 22 PSI
[Re: hemi-itis]
#1151208
01/06/12 11:50 PM
01/06/12 11:50 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I cut the Wix racing oil filter apart that I used on the new 505 motor that I dyno tested last month, it is the same type as the HP6, and it did have a bypass in it on the bottom I didn't know that it would bypass at 22 lbs I thought, before I cut it apart, that it was a non bypass filter like the GM are Oh well, back to the drawing boards
[Re: Cab_Burge]
#1151209
01/07/12 12:11 AM
01/07/12 12:11 AM
hemi-itis
The fram filter flows 20 GPM,my 100 year old milodon oil pump flows 19 GPM at an idle.I use a double oil filter set up with Moroso white filters that have NO BYPASS!! Most of the time the bypass is open with the fram filter,not filtering 85% of the oil Like Fred says,,,,,,,,,,don't ask me how I KNOW
[Re: HEMIFRED]
#1151212
01/07/12 10:56 AM
01/07/12 10:56 AM
70Cuda383
Marysville, O-H-I-O
wrong.it does not open unless there is 22 lb of resistance to the oil flow. It could also opened from a blocked filter or thick oil due to low temperature. if it didn't then oil flow to the enginewould stop. better unfiltered than none
I hear what you're saying, but...isn't "pressure" a "resistance" to flow? so if you're reading 30psi at idle, then you have 30psi worth of "flow resistance" Right?
Maybe I'm looking at it wrong... if the WHOLE system has 30 psi in it, from the pump to the sending unit, then there should be a "zero PSI" differential across the filter, and it's not in bypass... but if the filter became clogged, then while your gauge reads 40 at cruise, your clogged filter may actually have 80 psi on the "pump side" of it, and with the differential of 40 psi, the filter goes into bypass?
I have to say, 20 psi for a bypass to open seems stupid low, since most cars oil systems are a 30-75psi system.
