What size oil lines for remote filter and oil cooler? #1151076
01/05/12 09:50 PM
01/05/12 09:50 PM
Chicago, IL
blownEFI Offline OP
blownEFI  Offline OP
Chicago, IL
Wondering what size oil lines folks are running for remote filters and oil coolers?
I have AN-12 lines from my pan to my oil pump but I have only AN-10 lines for my remote oil filter. I'm adding an oil cooler in series with the filter so I'll be redoing those lines anyway. Should I stick with -10 or step those up to -12 ?
"These go to eleven", Nigel Tufnel
Re: What size oil lines for remote filter and oil cooler? [Re: blownEFI] #1151077
01/05/12 10:13 PM
01/05/12 10:13 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it kinda depends on the opening sizes of the cooler & your remote. i use -10 to my remote filter, i myself would set up to -12 if it was plumbing in a cooler as well. but thats me. why you adding a cooler?
Re: What size oil lines for remote filter and oil cooler? [Re: rebel] #1151078
01/05/12 10:23 PM
01/05/12 10:23 PM
Chicago, IL
blownEFI Offline OP
blownEFI  Offline OP
Chicago, IL
My remote filter housing and oil cooler both accept up to -12 size fittings.
I'm adding the oil cooler because my oil temps run about 215 degrees and I'd like to get them down to 190 or so.
