Metal strip under fender tag? #115106
09/04/08 02:56 PM
09/04/08 02:56 PM
Port Reading, NJ
roadrunner7070 Offline OP
Port Reading, NJ
The fender tag on my 70 Roadrunner has a strip of metal about the length of the fender tag and about 1/2" wide underneath it attached with one of the fender tag screws. Does anyone know what this is? It has 2 letters a "V" and "T" stamped right through it.
Re: Metal strip under fender tag? [Re: roadrunner7070] #115107
09/04/08 02:59 PM
09/04/08 02:59 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Not 100% but I think I remember it had to do with the assembly line..what car gets what..ect....again not 100% Sure...
Re: Metal strip under fender tag? [Re: 340dart4spd ] #115108
09/04/08 05:06 PM
09/04/08 05:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's an inspection tag. Usually they are removed at the end of the line at the factory after final inspection.
Re: Metal strip under fender tag? [Re: stumpy] #115109
09/04/08 05:07 PM
09/04/08 05:07 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
That's an inspection tag. Usually they are removed at the end of the line at the factory.
That sounds about right...
Re: Metal strip under fender tag? [Re: stumpy] #115110
09/04/08 05:09 PM
09/04/08 05:09 PM
Port Reading, NJ
Port Reading, NJ
Thanks. I wonder if I should paint it the same color as the fender tag and let it stick out from under the tag.
Re: Metal strip under fender tag? [Re: roadrunner7070] #115111
09/04/08 05:16 PM
09/04/08 05:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Normally body color. Why put it back at all?
Re: Metal strip under fender tag? [Re: stumpy] #115112
09/04/08 05:50 PM
09/04/08 05:50 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I have the exact same strip on my 70 roadrunner. Except mine just has the letter "E"
I never knew what it was, I just assumed it was some option that was added to the car after it left the factory or something like that.... I just repainted it the body color and put it back on.
