Which roller rockers with RPM heads #1150757
01/05/12 01:05 AM
01/05/12 01:05 AM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
Sorry about all the posts guys, I'm trying to take advantage of the 15% off code at Scummit and round up some of the bigger items I'll be needing.
Trying to decide which rockers I should pick up for my 508.
It has a decent sized Comp solid and RPM heads with Isky 8005 springs.
I am vascillating between:
Harland Sharp 1.5's at $561 after discount
Crane Gold 1.6's(the cam was spec'd for 1.6's) at $456
Comp Pro-Magnum 1.5's at $592
As always, cheaper is better but I don't want issues down the road. Eventually I plan on sticking a mild roller in it.
This is a 100% street car that we put about 2,000 miles/year on going to different shows and just beating around in having fun with it.
Max RPM will be around 5500-6000.
So, do I need to spend the extra $250 or will the Crane Gold's fill my needs?
Thanks for any/all input!
Jon
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Which roller rockers with RPM heads [Re: jon01] #1150758
01/05/12 01:49 AM
01/05/12 01:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running 1.5 H-S`s for 7+ years w/a .680-.660 solid roller cam and so far, so good.......... The cranes probably wont live with your future roller upgrade............
Re: Which roller rockers with RPM heads [Re: jon01] #1150759
01/05/12 01:59 AM
01/05/12 01:59 AM
NY NY
3
340duster340 Offline
NY NY
Can you share the discount code?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Which roller rockers with RPM heads [Re: 340duster340] #1150760
01/05/12 02:09 AM
01/05/12 02:09 AM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
Re: Which roller rockers with RPM heads [Re: jon01] #1150761
01/05/12 02:14 AM
01/05/12 02:14 AM
tn
robnbird Offline
robnbird  Offline
tn
don't go cheep on the rocker arms or anything valve train, Harlan Sharp.
Re: Which roller rockers with RPM heads [Re: robnbird] #1150762
01/05/12 02:18 AM
01/05/12 02:18 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Harland sharps all the way. I bought mine from Dan (performance only). He and I had a great discussion on them and he sold me on them. Good stuff and well worth the money. I agree with the above poster don't go cheap with this part of the build.
Mike
1969 Dodge Dart Swinger
Re: Which roller rockers with RPM heads [Re: MikeyT] #1150763
01/05/12 03:24 AM
01/05/12 03:24 AM
Delray beach, Florida
P
Performance Only Offline
P
Michael, thanks for the kind words.
Harland Sharp has 1.6 rockers also if you want to go that route. i agree with the others that rocker arms are not a good place to skimp on the budget. they are a few dollars more than some other brands, but they're a much better product than many of the others too. let me know if i can help.
machine shop owner and engine builder
Re: Which roller rockers with RPM heads [Re: jon01] #1150764
01/05/12 04:13 AM
01/05/12 04:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like the Hughes roller rockers I use on my 493 with the EZ heads. They have been working fine and holding up good. Ron
Re: Which roller rockers with RPM heads [Re: jon01] #1150765
01/05/12 04:27 AM
01/05/12 04:27 AM
Cab_Burge Online work
Cab_Burge  Online Work
https://board.moparts.org/ubbthreads/show...e=1#Post6999715
Buy the best you can afford once, not buy the cheaper ones several times I have several sets of Harland Sharps, one older set of 1.5 and two newer sets of 1.6, all three sets check bigger at the retainers than advertizsed on the ratio The 1,5 check to be 1.54 actaul and both sets of 1.6 are actually 1.65 at the retainers Two of the sets are on roller cam motors with lots of srping pressures,625 LBs+ and the older set is on motor with hydraulic flat lifters with 350 lbs open pressure. I swear by them, I have had cheaper ones in the past, I got what I paid for
Re: Which roller rockers with RPM heads [Re: jon01] #1150766
01/05/12 10:29 AM
01/05/12 10:29 AM
an8sec70cuda Offline
Harland Sharps all the way. I ran them on my old 440 w/ Edelbrock heads and they're on my Indy SR heads now.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which roller rockers with RPM heads [Re: jon01] #1150767
01/05/12 10:42 AM
01/05/12 10:42 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Edlebrock recomended that I run 1.5 rockers on there heads and use the cam with the lift that I want.
I have been running 1.5 Crane gold roller rockers on both of my cars with RPM heads for 15 years on my 340 and 6 years now on my 440. No trouble ever. I ran Crane gold roller rockers on several 572 chevy motors with roller cams that I drag raced in a dragster with close to .800" lift and never had a failure either. Ran 6.80s at 200MPH with it.
Re: Which roller rockers with RPM heads [Re: Challenger 1] #1150768
01/05/12 11:23 AM
01/05/12 11:23 AM
tboomer Online work
tboomer  Online Work
Competitionwedge(Todd) had a hot deal going on the Harland Sharps here a while back...He is a good guy...Maybe he could help you?
Re: Which roller rockers with RPM heads [Re: tboomer] #1150769
01/05/12 01:32 PM
01/05/12 01:32 PM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
Ok, Harland's it is.
Thanks for the input guys!
Re: Which roller rockers with RPM heads [Re: tboomer] #1150770
01/05/12 03:48 PM
01/05/12 03:48 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thanks TEd.
Be aware, standard h
Harland Sharps WILL work on the RPM heads, but the fitment is not as exact as I would like to see. I offer sets made to better align the roller tips for RPM heads. Let me know if I can help.
RIP Monte Smith
Re: Which roller rockers with RPM heads [Re: CompWedgeEngines] #1150771
01/05/12 03:54 PM
01/05/12 03:54 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
67' charger 499 RB 10.57 at 127
Re: Which roller rockers with RPM heads [Re: dragram440] #1150772
01/05/12 04:38 PM
01/05/12 04:38 PM
Anyone ever run these?
http://www.ebay.com/itm/Mopar-361-440-19...=item19cc17c610
You get what you pay for.
CHIP
Re: Which roller rockers with RPM heads [Re: jon01] #1150773
01/05/12 04:54 PM
01/05/12 04:54 PM
AndyF Offline
AndyF  Offline
I'd suggest looking at the Hughes rocker arms. I used to always recommend the RAS rocker arms but I don't think they are available anymore. I know that Dave at Hughes has been working hard on rocker arm systems. There are a lot of little issues that he has sorted out with his latest design.
Re: Which roller rockers with RPM heads [Re: AndyF] #1150774
01/05/12 05:00 PM
01/05/12 05:00 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I am looking for a set for a mild street strip 440 with edelbrock rmp's with the 590 purpleshaft cam. I ran a set of cheap pro forms for years and they seem to work good for me on that. These ones have the bearing in them and they have the nice 12 pt. nut with adjuster. These look nice compared to my old mopar permormance aluminum ones Im running with my roller cam 500.
Re: Which roller rockers with RPM heads [Re: dragram440] #1150775
01/05/12 05:07 PM
01/05/12 05:07 PM
P
P
IMO, the needle beraings are spaced too far apart on those. there are other issues, but i'll leave it at that.
Re: Which roller rockers with RPM heads [Re: Performance Only] #1150776
01/05/12 05:29 PM
01/05/12 05:29 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Thats why I asked. Are you better off without the bearing like the ones I am running on my 500?
