Re: Which roller rockers with RPM heads
[Re: CompWedgeEngines]
#1150782
01/05/12 10:49 PM
01/05/12 10:49 PM
Posts: 3,142 Central NC
gch
Central NC
Thanks TEd.
Be aware, standard h Harland Sharps WILL work on the RPM heads, but the fitment is not as exact as I would like to see. I offer sets made to better align the roller tips for RPM heads. Let me know if I can help.
Does this hold true for the 440 source heads?
Sorry for thread hijack btw.
[Re: gch]
#1150783
01/06/12 03:49 AM
01/06/12 03:49 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
They will work fine on the stealth head. I had them on mine.
Mike
1969 Dodge Dart Swinger
[Re: BradH]
#1150785
01/06/12 01:14 PM
01/06/12 01:14 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Note the elongated axle holes on this less than a month old set!
RIP Monte Smith
#1150786
01/06/12 01:19 PM
01/06/12 01:19 PM
CompWedgeEngines
Syracuse,NY
as well as the failing upper bridge portion of the rocker body and axle....not good, very poor copies.
The Hughes stuff does seemed priced well and a good value. I think the H/S could hold up a bit better under a little higher loads,and I have some long term experince with them in many brakcet and Super Gas type cars, but not sure what your future plans are, so thats got to be your call there.
The last few set of Cranes I ordered were still the " old" style, and they had not yet started shipping their new pieces, so until that happens, I cant say how godd they actually will be.Roller cams in my opinion need a little better rocker for long term service. Small roller snad solids, the Cranes did work great on.
RIP Monte Smith
[Re: 383man]
#1150789
01/06/12 03:02 PM
01/06/12 03:02 PM
BradH
I like the Hughes roller rockers I use on my 493 with the EZ heads. They have been working fine and holding up good. Ron
I ran them w/ my Stage VIs and a solid flat-tappet cam w/ good results. I'm hoping they're up to running with 200#s more open spring load w/ the new roller cam.
