Sorry about all the posts guys, I'm trying to take advantage of the 15% off code at Scummit and round up some of the bigger items I'll be needing.
Trying to decide which rockers I should pick up for my 508.
It has a decent sized Comp solid and RPM heads with Isky 8005 springs.
I am vascillating between:
Harland Sharp 1.5's at $561 after discount
Crane Gold 1.6's(the cam was spec'd for 1.6's) at $456
Comp Pro-Magnum 1.5's at $592
As always, cheaper is better but I don't want issues down the road. Eventually I plan on sticking a mild roller in it.
This is a 100% street car that we put about 2,000 miles/year on going to different shows and just beating around in having fun with it.
Max RPM will be around 5500-6000.
So, do I need to spend the extra $250 or will the Crane Gold's fill my needs?
Thanks for any/all input!
Jon
