Is a deep pan necessary? #1150607
01/04/12 11:01 PM
01/04/12 11:01 PM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
I'm getting the last of the parts needed to get the 508 into my 68 Coronet wagon.
Last thing I need to figure out is an oil pan.
I got a 440 source deep pan with the motor, however I'd really rather not run it as the car does sit pretty low and dragging the pan on bumps doesn't sound like a good time to me.
Wondering if I can get away with a hemi pan/pickup setup.
The motor does have a HV pump on it.
What say you Moparts gods?
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Is a deep pan necessary? [Re: jon01] #1150608
01/04/12 11:24 PM
01/04/12 11:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Ditch the HV pump and avoid prolonged periods of elevated RPM's ........ you should be fine with the Hemi pan.
I have had motors suck the pan dry after extended freeway romps........no kind of fun I'd recommend.
Re: Is a deep pan necessary? [Re: tubtar] #1150609
01/04/12 11:29 PM
01/04/12 11:29 PM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
I can do that.
I should clarify - I do plan on putting a centri blower on this thing next year so the added volume may come in handy. I do see where you are coming from, haven't done it personally but do know folks who've lunched main bearings as a result of that.
Highway pulls won't likely take long with the power this thing should make(700+) so extended high RPM operation won't be an issue.
Re: Is a deep pan necessary? [Re: jon01] #1150610
01/04/12 11:35 PM
01/04/12 11:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If you choose NOT to use the deep pan,an accusump is good insurance
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Is a deep pan necessary? [Re: jon01] #1150611
01/04/12 11:41 PM
01/04/12 11:41 PM
IN
ahy Offline
ahy  Offline
IN
The Hemi pan is a good one. The Hemi pan plus 3 qt oil accumulator is pretty much bullet proof. If your engine needs/wants the HV pump due to bearing clearance or full groove bearings, I'd go ahead and run it.
Even the Hemi pan is an inch or so deeper than stock... a K frame mounted skid plate is a good idea.
The attached is a "thread within a thread" on skid plates.
https://board.moparts.org/ubbthreads/show...rue#Post6995942
Re: Is a deep pan necessary? [Re: jon01] #1150612
01/05/12 12:30 AM
01/05/12 12:30 AM
There are two different 426 street hemi oil pans, 1966 to 1969 and the better 1970-71 I use the 1970-71 6 pak oil pan with the stock factory 1970-71 440 6pak oil pickup(3/8, not the 1/2 inch one My motors normally have more bearing clearnances than some others use and most of my motors have the rocker assembllys oiled full time so my motors have more oil circulating in them than some of the other stocker type B/RB motors out there have The 1970-71 hemi 6 pak oil pans work great Besides they hold 6 quarts in the sump as well as one in the filter instead of 5 like the earleir deeper sump street hemi pans held The later oil pans fit in the all the 1966 to 1971 B/RB B body K members very well
Re: Is a deep pan necessary? [Re: ahy] #1150613
01/05/12 12:32 AM
01/05/12 12:32 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I'm running the 440Source 7 quart pan on my 440 '67 Satellite and I haven't had any issues with the pan hitting. And I drive it a lot on all kinds of roads with little 215/70-14 tires on the front. Haven't hit or scrapped it yet. I do slow way down for speed bumps in parking lots.
Re: Is a deep pan necessary? [Re: 67Satty] #1150614
01/05/12 12:36 AM
01/05/12 12:36 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
DEEP pan ...longer sump ...whatever ... a good supply of oil is the BESTest idea..
Re: Is a deep pan necessary? [Re: 67Satty] #1150615
01/05/12 12:37 AM
01/05/12 12:37 AM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
Would you be willing to post a pic of your car?
I would really rather run the deep pan if I can get away with it but I am very nervous about dragging it on something when we're 100's of miles from home on Power Tour or doing something else.
Re: Is a deep pan necessary? [Re: dOc !] #1150616
01/05/12 12:38 AM
01/05/12 12:38 AM
Iowa
jon01 Offline OP
jon01  Offline OP
Iowa
Agreed 100%.
Next winter I plan on sticking a tubular K under the car at which point I'll add an extension on to the sump of the stock pan to give more capacity.
Re: Is a deep pan necessary? [Re: jon01] #1150617
01/05/12 12:58 AM
01/05/12 12:58 AM
hemi-itis Offline
hemi-itis  Offline
I've been running this Milodon system for over 20 years.Only scrapped the pan once when a rim cracked and lost air,,,,,,,,FAST I was in the middle lane,tire went flat and I almost hit the curb in the left lane,yanked the wheel to the right and the pan scrapped.Other than that I'm carefull
Re: Is a deep pan necessary? [Re: hemi-itis] #1150618
01/05/12 01:04 AM
01/05/12 01:04 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
TYPICAL Sat nite 'itis ? ... was all-that caused by you missing a shift ? ..
Re: Is a deep pan necessary? [Re: dOc !] #1150619
01/06/12 12:41 AM
01/06/12 12:41 AM
maryland
buck440 Offline
buck440  Offline
maryland
i run the 402 pan an high pressure pump rather than high volume works great.
Re: Is a deep pan necessary? [Re: buck440] #1150620
01/06/12 02:00 AM
01/06/12 02:00 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
HP or HV ? ... through a set oil passage size ...same/same.
Re: Is a deep pan necessary? [Re: dOc !] #1150621
01/06/12 05:35 AM
01/06/12 05:35 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
had a 383 with hv pump, mild rebuild- 3/4's into the 1/4 mile it makes some noises... 2 main bearings and 4 rod bearings and 2 rods later i was back in action, with a BIG pan.
Re: Is a deep pan necessary? [Re: 8urvette] #1150622
01/06/12 12:05 PM
01/06/12 12:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You got off easy ... same situation - mine put a rod through the block and took out the cam and pretty much everything else. This was due to running the high volume (Ramchargers kit) pump and a hemi pan. Now I run the biggest pan and the stock pump with pressure adjustment.
