Re: 69 cuda LBS
[Re: bluebird69]
#1150598
01/06/12 03:41 AM
01/06/12 03:41 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
My 69 notchback is now stripped down to the bare one-piece body shell for restoration. I plan to weigh it in the near future.
Meantime, all the body sheet metal - doors, hood, trunk lid, front fenders, grille panels, etc. are also bare.
PM me if you want weights of these parts. You might need a list of what each part weighs in steel and in fiberglas to figure out weight savings.
Re: 69 cuda LBS
[Re: kentj340]
#1150599
01/25/12 12:30 AM
01/25/12 12:30 AM
kentj340
Cut and Shoot, TX
Body part weights, 69 Barracuda notchback. All parts below are totally bare, unless noted.
R or L door, each, 32 lbs K frame, 33 Trunk, 39 Hood, 56 R or L fender, ea, 23 Rear axle w brake backing plates, 3rd member, rear yoke, 55 Drive shaft w front yoke, both U joints, 15 Rear springs, pair, w bushings, 87 One front brake drum 10" w outer races, lug studs, 17.5 Pair tail pipes, 12 Front sway bar w 2 mount brackets, cushions, 11 2 mufflers w 2 head pipes, no clamps, 38
Re: 69 cuda LBS
[Re: kentj340]
#1150600
01/30/12 01:10 AM
01/30/12 01:10 AM
kentj340
Cut and Shoot, TX
Following parts are weighed bare, without any attachments or fasteners.
Front or rear bumper, 14.5 lbs ea, total 29 lbs.
Two rear bumper bars, 4 lbs ea, total 8 lbs.
Four front bumper bars, 3.5 lbs ea, total 14 lbs.
Re: 69 cuda LBS
[Re: kentj340]
#1150601
02/07/12 07:49 PM
02/07/12 07:49 PM
kentj340
Cut and Shoot, TX
Here's the weight of a totally stripped 69 Barracuda notchback, in case you want to trailer one, make a wheeled frame for it, or if you want to raise the front of one to roll an engine-K frame assembly underneath.
A. With the rear of the body supported 1" in front of the front spring brackets, each rear side weighs an average of 186 lbs, and the front weighs 89 lbs, for a total of 461 lbs. If you place your human body weight in the trunk area (to do work on the rear window frame, for example), the front of the car will rise, unless you add additional support under the rear.
B. If you move the rear supports more forward from the front spring brackets than 1", the weight of the front end approaches zero or less. In other words, when the supports are in front of the center of gravity, the car will tip backwards.
Here's a photo showing how a bathroom scale was used to weight 3 points on the car. A 2" dia washer transmitted the weight to the yellow square tube, and another 2" washer transmitted the weight to the scale. The weight of the square tube was deducted from the weight of both rear sides.
The weight of a stripped B or E body 2-door should be not much different.
