Re: 68 RR Driveshaft Restoration
[Re: rc68rr]
#1150170
01/05/12 06:26 PM
01/05/12 06:26 PM
Now can someone tell me what to use to get it warm enough to apply the RPM Thanks
Hi everyone,
When we coated the driveshaft with RPM on Project Valiant we used a heat gun( I bought one at Harbour Freight for $9 on sale) and started at one end and slowly worked toward the other end. You can turn the driveshaft as you go to keep the shaft warm. Works good with two people but one person and saw horses works also. On a smooth surface you will probably notice some brush strokes but they can be handled at the end since you'll probably want to use a towel and a little heat to smooth out any brush strokes. Normally the shafts have a little sheen which can be achieved with a clean cloth towel once it cools.
At the end of the day you are not going to have a lot of build up of RPM on the part for protection. In fact if you really apply a lot then it changes the appearance and could appear cloudy. We have actually melted RPM and dipped parts. You have to use the heat gun and brush to remove excess or it could be too thick. Just ensure that you have your part completely covered for best protection. Since it goes on glossy this should help verify coverage. A final pass with the heat gun allows the RPM to flow out and most brush strokes disappear on their own.
I have used a similar technique on a late model K frame where I wanted to do both sides. Dave swapped the white Challenger over from the oil based product used in 2008 to RPM in an afternoon on the lift. It was dramatic how it changed the look of the car and got rid of that oily residue.
All great questions and a great idea on the PVC pipe to soak the whole shaft.
[Re: His and Her 69's]
#1150173
01/06/12 12:24 PM
01/06/12 12:24 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Must be working for me because i'm a member. Anyway if you do a google search you will find a lot about it, keep in mind i was using it for chrome plated parts, so not sure how and to what ratio to mix if your going to do something like a drive shaft or cyl head. Its cheap enough to experiment with at around $5.
[Re: rc68rr]
#1150177
01/08/12 06:17 AM
01/08/12 06:17 AM
Where can you buy RPM ??
Here's the website that has some more information on the product.
www.ecsautomotive.com
toll free 1-855-532-7846
It's $34.95 for an 8 oz container which contains enough for your whole restoration project. Shipping in the US is $6.00. The new container is now shipping - same great product.
