68 RR Driveshaft Restoration #1150146
01/04/12 01:04 AM
01/04/12 01:04 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
I soaked the driveshaft in evap o rust & it came out looking like new. Now what should I coat it with so it stays that way ? I would like it to have the correct finish on it. The u joint strap looks awsome you can read the date on it 10 9 67 (I need 1 strap Help ). Thanks everyone
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150147
01/04/12 01:08 AM
01/04/12 01:08 AM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
RPM
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150148
01/04/12 01:20 AM
01/04/12 01:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How much evaporust did you have to use to do that ?
Re: 68 RR Driveshaft Restoration [Re: JohnRR] #1150149
01/04/12 02:27 AM
01/04/12 02:27 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i was thinking the same thing..
he must of have a 5 gallon bucket of it.
Re: 68 RR Driveshaft Restoration [Re: flypaper] #1150150
01/04/12 02:30 AM
01/04/12 02:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The stuff is about $29.00 a gal here at Harbor Frieght and it doesn't go very far concerning how many rusty parts it will derust, but it does work well when fresh. I'd use a slightly oversized length of PVC pipe to hold it for a drive shaft.
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150151
01/04/12 10:46 AM
01/04/12 10:46 AM
PA
BTTG Offline
BTTG  Offline
PA
I had been paying $25/gallon at Summit as that was the cheapest i had found.
last time I was at my local autozone i noticed they started carrying the gallon bottles for $19.99....previously they only had the quart containers for $9.99. cheapest i have ever seen it.
Re: 68 RR Driveshaft Restoration [Re: BTTG] #1150152
01/04/12 11:33 AM
01/04/12 11:33 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I calculated it out before I soaked my driveshaft. The shaft takes up most of the volume of the PVC so you don't need much EvapoRust at all. If I remember correctly, you only need a little over a gallon to submerge the driveshaft using 5" PVC.
Re: 68 RR Driveshaft Restoration [Re: burdar] #1150153
01/04/12 02:20 PM
01/04/12 02:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
you can use wood bleach also to remove rust. about $5 for a little plastic tub and will probably make 200 gal. use about i tablespoon per gal.
Re: 68 RR Driveshaft Restoration [Re: BTTG] #1150154
01/04/12 07:44 PM
01/04/12 07:44 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i've seen it around the internet for 70 to 80 bucks plus a stamp for a 5 gallon pail
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150155
01/04/12 08:18 PM
01/04/12 08:18 PM
MD
floyd Offline
floyd  Offline
MD
There's some more good stuff about drive shaft resto in this post (about midway through the post). I think that he did his before RPM was available though.
https://board.moparts.org/ubbthreads/show...rt=all&vc=1
Re: 68 RR Driveshaft Restoration [Re: floyd] #1150156
01/04/12 09:55 PM
01/04/12 09:55 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
I used 1 1/2 gallons in a 4" piece of pvc pipe let it soak for a week. Cost was 19.99 a gal @ the hardware store. I will try and post some pictures.
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150157
01/04/12 10:57 PM
01/04/12 10:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
ademon, that sounds interesting! Where do you find wood bleach? Can you post and before after results and or any tips?
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150158
01/05/12 01:29 AM
01/05/12 01:29 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Before evap o rust
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150159
01/05/12 01:31 AM
01/05/12 01:31 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
After evap o rust
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150160
01/05/12 01:31 AM
01/05/12 01:31 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Last one
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150161
01/05/12 01:34 AM
01/05/12 01:34 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Now can someone tell me what to use to get it warm enough to apply the RPM Thanks
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150162
01/05/12 01:48 AM
01/05/12 01:48 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used a heat gun. It took a long time to heat it up but it got the job done. Putting it out in the sun would work too depending on the time of year.
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150163
01/05/12 10:46 AM
01/05/12 10:46 AM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
Not much Evaporust at at, as was said purchase a PVC pipe, and very little volume around it when submerged. Used a 2x4 to submerge it and stood it up in the corner for a couple days.
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150164
01/05/12 02:20 PM
01/05/12 02:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I used it on a few bikes i restored, mostly the chrome parts, haven't tried it yet on engine/car stuff yet. works real nice on chrome, usually between a teaspoon to tablespoon per gallon is all you need for delicate stuff like chrome or items that have paint. You can probably go heavier for cast iron stuff. Here is a link to the musclebike forum where i learned about it. I got mine at DIY/ACE hardware for like $5.
http://musclebikeforums.com/topic/8830/Wood-Bleach-Oxalic-Acid
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150165
01/05/12 02:27 PM
01/05/12 02:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
here is a sissy bar that i soaked overnight.
