Positive battery terminal #115015
09/04/08 10:27 AM
09/04/08 10:27 AM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Anyone know where I can buy a new battery terminal that isn't one of those ugly type with the bolts holding the cable on? I thought someone made a terminal where the cable slid inside the rear of the terminal and was held in place with a set screw from the bottom??
Re: Positive battery terminal [Re: Siba] #115016
09/04/08 10:29 AM
09/04/08 10:29 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I bought mine from Paddock a few years ago. Cost almost as much as a cable now. It has been on my car for 5 years or so no problems. Mike
POSITIVE BATTERY CABLE HEAD
THIS IS A GREAT ALTERNATIVE TO REPLACING THE ENTIRE CABLE. LOOKS LIKE A FACTORY CABLE END. HAS SET SCREWS IN THE BOTTOM TO RETAIN WIRES.
Product Number QPR1
Re: Positive battery terminal [Re: Siba] #115017
09/04/08 10:31 AM
09/04/08 10:31 AM
i dont know where to get one but experience has shown that those terminals (any screw on type) are a problem waiting to happen. maybe great for an emergency BUT with the high current they pass, corrosion that WILL form between the wire and the terminal WILL cut down your cranking power and eventually leave you stranded.
New cables are about $30 and are well worth it.
Re: Positive battery terminal #115018
09/04/08 10:34 AM
09/04/08 10:34 AM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Forgot to mention that I'm working on my brothers truck.... 2000 GMC. So the replacement cable is not cheap.
Re: Positive battery terminal [Re: Siba] #115019
09/04/08 10:38 AM
09/04/08 10:38 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Isn`t that a side post battery?
http://cgi.ebay.com/ebaymotors/POSITIVE-...sspagenameZWD1V
Re: Positive battery terminal [Re: mopars4ever] #115020
09/04/08 10:48 AM
09/04/08 10:48 AM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Yes, it's a side post. Thanks for the help!
Re: Positive battery terminal [Re: Siba] #115021
09/04/08 11:07 AM
09/04/08 11:07 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
THey make many cable ends that solder on, crimp on etc, and then get heat shrinked with some nice thick material at my workplace. The problem is they work best if you remove them from vehicle first and can deal with them on the bench. I don't know the mfgs of the stuff though....
