Re: 68 RR Driveshaft Restoration [Re: ademon] #1150166
01/05/12 02:29 PM
01/05/12 02:29 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
here is the bike i restored, all the chrome parts had rust, soaked all the chrome in the wood bleach. before
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150167
01/05/12 02:31 PM
01/05/12 02:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
after,
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150168
01/05/12 04:29 PM
01/05/12 04:29 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I've got an old Sears bike that needs restored.
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150169
01/05/12 04:31 PM
01/05/12 04:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Link doesn't work ademon?
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150170
01/05/12 06:26 PM
01/05/12 06:26 PM
Now can someone tell me what to use to get it warm enough to apply the RPM Thanks
Hi everyone,
When we coated the driveshaft with RPM on Project Valiant we used a heat gun( I bought one at Harbour Freight for $9 on sale) and started at one end and slowly worked toward the other end. You can turn the driveshaft as you go to keep the shaft warm. Works good with two people but one person and saw horses works also. On a smooth surface you will probably notice some brush strokes but they can be handled at the end since you'll probably want to use a towel and a little heat to smooth out any brush strokes. Normally the shafts have a little sheen which can be achieved with a clean cloth towel once it cools.
At the end of the day you are not going to have a lot of build up of RPM on the part for protection. In fact if you really apply a lot then it changes the appearance and could appear cloudy. We have actually melted RPM and dipped parts. You have to use the heat gun and brush to remove excess or it could be too thick. Just ensure that you have your part completely covered for best protection. Since it goes on glossy this should help verify coverage. A final pass with the heat gun allows the RPM to flow out and most brush strokes disappear on their own.
I have used a similar technique on a late model K frame where I wanted to do both sides. Dave swapped the white Challenger over from the oil based product used in 2008 to RPM in an afternoon on the lift. It was dramatic how it changed the look of the car and got rid of that oily residue.
All great questions and a great idea on the PVC pipe to soak the whole shaft.
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150171
01/06/12 03:43 AM
01/06/12 03:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
it works for me
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150172
01/06/12 03:51 AM
01/06/12 03:51 AM
Oh
His and Her 69's Offline
Oh
Doesn't work for me either???
David
Re: 68 RR Driveshaft Restoration [Re: His and Her 69's] #1150173
01/06/12 12:24 PM
01/06/12 12:24 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Must be working for me because i'm a member. Anyway if you do a google search you will find a lot about it, keep in mind i was using it for chrome plated parts, so not sure how and to what ratio to mix if your going to do something like a drive shaft or cyl head. Its cheap enough to experiment with at around $5.
Re: 68 RR Driveshaft Restoration [Re: ademon] #1150174
01/07/12 07:52 PM
01/07/12 07:52 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Where can you buy it. I can't get the link to work either. Thanks
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150175
01/07/12 09:34 PM
01/07/12 09:34 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: 68 RR Driveshaft Restoration [Re: ScottSmith_Harms] #1150176
01/07/12 11:10 PM
01/07/12 11:10 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Where can you buy RPM ??
Re: 68 RR Driveshaft Restoration [Re: rc68rr] #1150177
01/08/12 06:17 AM
01/08/12 06:17 AM
Here's the website that has some more information on the product.
www.ecsautomotive.com
toll free 1-855-532-7846
It's $34.95 for an 8 oz container which contains enough for your whole restoration project. Shipping in the US is $6.00. The new container is now shipping - same great product.
