Re: 2007 ram 2500 rear blinker not working
[Re: rallye73]
#1150065
01/03/12 11:58 PM
01/03/12 11:58 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
I got fooled one time and by mixing up which bulb i was checking. The brake light and turn light are separate. If not you may have to check for codes in the fcm I think. I had one similar where once we cleared the codes it worked fine and hasnt been a problem since.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: rallye73]
#1150066
01/04/12 08:21 PM
01/04/12 08:21 PM
Posts: 118 Winesburg Ohio
mattpar
Winesburg Ohio
no break lights, it seems that with the factory trailer lights, that they are seperate wires all the way to the front. And they work. I could rig them up and i can get the rears to work with by tying into the traier wires. But that wouldn't be totaly right
If you have to force it, then somethings wrong!
[Re: mattpar]
#1150067
01/04/12 10:19 PM
01/04/12 10:19 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
there is a circuit board for the tail lights under the hood that is known to go bad
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: BEINGmeISaCRIME]
#1150071
01/05/12 08:46 AM
01/05/12 08:46 AM
Posts: 1,377 Ohio
Todd
Ohio
Love it when people "back probe" by jamming the t-pin through the wire...
Thats not what i ment. Back probe the connector. Should have been more clear on that. Sorry. Make sure the T-pin you use easily fits in the backside of the connector along side the wire.
[Re: Todd]
#1150072
01/05/12 05:57 PM
01/05/12 05:57 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
I knew what'cha meant. Some people that are in my auto tech class backprobed by jamming a t-pin through the wire... makes me wonder what goes through their mind.
#1150073
01/05/12 08:15 PM
01/05/12 08:15 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Hopefully a T-pin! Have had to fix a lot of wiring because of this kind of tech!
