No heat in 96 Dakota V6,,help #1149731
01/02/12 10:16 PM
01/02/12 10:16 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
right when the real cold of winter flares up, my truck decides it doesn't need to keep me warm anymore. Basically it started the other day with ...stays cold after about 20 minutes of run time, then gets sorta warm...well tonight I ran it 50 minutes on the interstate and I could still see my breath in front of me as i got to the house..my toes are numb.
I noticed that the factory temp gauge would go from Cold...slowly crawl to Hot, then instantly drop down to a mid range level...seems to do it nearly everytime.
I checked the heater hoses after shutting it off..they are only warm from the engine heat...the top radiator hose is fairly warm..the bottom one is warm from the engine heat..nothing feels toasty hot.
Any input? 150,000 miles, i replaces pump about a year and a half ago.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: No heat in 96 Dakota V6,,help [Re: MonGoo$e] #1149732
01/02/12 10:19 PM
01/02/12 10:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
replace the t-stat
Re: No heat in 96 Dakota V6,,help [Re: mopars4ever] #1149733
01/02/12 10:23 PM
01/02/12 10:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the water level and antifreeze mix. I had a weak af mix in one of my cars and it actually froze when I drove without letting the engine warm up. Darn near cost me a motor before I caught it.
Re: No heat in 96 Dakota V6,,help [Re: MonGoo$e] #1149734
01/02/12 10:29 PM
01/02/12 10:29 PM
western new york
horsepower.2007 Offline
western new york
If anyone has ever run stop-leak through the system there is a good chance the heater core is plugged. If so, you will have to remove both heater hoses and flush core both ways.
Re: No heat in 96 Dakota V6,,help [Re: stumpy] #1149735
01/02/12 10:30 PM
01/02/12 10:30 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
sounds like no coolant or air in the system
Re: No heat in 96 Dakota V6,,help [Re: AARCONV] #1149736
01/02/12 10:36 PM
01/02/12 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
if the gauge went to hot then drops... its
low on coolant and then it got a slug of coolant
Re: No heat in 96 Dakota V6,,help [Re: MR_P_BODY] #1149737
01/02/12 10:50 PM
01/02/12 10:50 PM
Tucson AZ
2
2cudabuck Offline
2cudabuck  Offline
Tucson AZ
I've got the same problem in my 98 V8 dak. However, I noticed a tiny drip when I'm running the heater coming from a weep tube about middle of the firewall near the bottom. My diagnosis seems clear, someone put stop leak in it, it completely plugged it with the exception of the leak out of the condensate hose. I'll be putting in a new core and flushing.
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: No heat in 96 Dakota V6,,help [Re: MonGoo$e] #1149738
01/02/12 10:58 PM
01/02/12 10:58 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I have a 92 with the same problem, haven't been worried about it but now its getting cold out.
Re: No heat in 96 Dakota V6,,help [Re: RV2] #1149739
01/03/12 01:19 AM
01/03/12 01:19 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The heater core gets easily clogged. If you don't flush the system regularly, just flush your heater core by disconnecting the hoses and running water thru the core. Chances are if you disconnect them at the firewall, you will see the blockage. Run the outlet hose into a catch can. I bet it will look like mud coming out. Do that before you change T stats or spend any money onany expensive service.
Re: No heat in 96 Dakota V6,,help [Re: RoadRunnerJD] #1149740
01/03/12 02:52 AM
01/03/12 02:52 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
thanks for the advice guys, I'll try and mess with it tomorrow as I have another day off.
Re: No heat in 96 Dakota V6,,help [Re: MonGoo$e] #1149741
01/03/12 02:03 PM
01/03/12 02:03 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
My 93 V6 would do the gauge thing, go from cold to almost pegged, than back down. It would fry your feet if kept at highest hot.
Sounds like a blockage or air. Have you put the hoses on backwards maybe?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: No heat in 96 Dakota V6,,help [Re: Magnumguy] #1149742
01/03/12 07:58 PM
01/03/12 07:58 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Sounds like your blower works, but no heat?
My '90 3.9 Dakota would not product heat brand new off the dealer lot. Defective thermostat was stuck open. New thermostat got the heat back. On a higher mileage truck though, I'd agree an air bubble or heater core blockage.
I did have a friend that had a F250 diesel with no heat. His problem was a big air bubble in the heater core, system had to be burped, then he had heat.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
