Re: No heat in 96 Dakota V6,,help
[Re: MonGoo$e]
#1149732
01/02/12 10:19 PM
01/02/12 10:19 PM
Posts: 13,574 md
mopars4ever
md
[Re: AARCONV]
#1149736
01/02/12 10:36 PM
01/02/12 10:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
sounds like no coolant or air in the system
if the gauge went to hot then drops... its low on coolant and then it got a slug of coolant
[Re: MR_P_BODY]
#1149737
01/02/12 10:50 PM
01/02/12 10:50 PM
Posts: 173 Tucson AZ
2cudabuck
Tucson AZ
I've got the same problem in my 98 V8 dak. However, I noticed a tiny drip when I'm running the heater coming from a weep tube about middle of the firewall near the bottom. My diagnosis seems clear, someone put stop leak in it, it completely plugged it with the exception of the leak out of the condensate hose. I'll be putting in a new core and flushing.
Buck
67 273 Dart GT
69 RT 440 Charger (SWEET!)
70 318 Cuda
74 Cuda Packin a 426 roller Hemi
[Re: Magnumguy]
#1149742
01/03/12 07:58 PM
01/03/12 07:58 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Sounds like your blower works, but no heat?
My '90 3.9 Dakota would not product heat brand new off the dealer lot. Defective thermostat was stuck open. New thermostat got the heat back. On a higher mileage truck though, I'd agree an air bubble or heater core blockage.
I did have a friend that had a F250 diesel with no heat. His problem was a big air bubble in the heater core, system had to be burped, then he had heat.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
