Re: do you run a windage tray in your 440?
[Re: 383man]
#1148875
01/02/12 10:33 PM
01/02/12 10:33 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I make my own crank scrapers and use the stock Mopar stock stroke windage trays I open up the louvers on the side for better drain back I do use the two oil pan gaskets bewtween the scraper and windage tray, I cut one in half and glue it on the block up to the crank scraper, the scraper is glue onto the other side of the block and then one thick Fel Pro gasket on top of the scraper and half gasket, another thick Fel Pro between the oil pan and windage tray I have since started adding more drain back holes at every main cap like the one in the picture on the right side, I took this picture before adding those additional holes
[Re: viperblue72]
#1148879
01/05/12 10:31 AM
01/05/12 10:31 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Yep, I use one on every BB I build. The Milodon tray is much nicer than the MP tray.
[Re: dOrk !]
#1148881
01/05/12 11:10 AM
01/05/12 11:10 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I use the miloden standard stroke one. It seemed to clear my 4.15 stroke crank so I just figured it would be ok.
67' charger 499 RB
10.57 at 127
[Re: PorkyPig]
#1148883
01/05/12 02:16 PM
01/05/12 02:16 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I use the MP tray. I pry'd the drainback slots to be a little bigger.
