do you run a windage tray in your 440? #1148868
01/02/12 06:51 PM
01/02/12 06:51 PM
junction city oregon
V
viperblue72 Offline OP
V
It seems like the crank is high enough in the crankcase that I may not matter, but this is my first 440 build. What are your opinions?
Fwiw I'm putting in a 4.15 crank.
Re: do you run a windage tray in your 440? [Re: viperblue72] #1148869
01/02/12 07:13 PM
01/02/12 07:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i did on a 493. a crank scraper is better than messing around with 2 gaskets on a tray. if ur going to use a tray, make sure it has plenty of louvers for drain back. seeya.
Re: do you run a windage tray in your 440? [Re: rickraw] #1148870
01/02/12 07:47 PM
01/02/12 07:47 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
with out it my oil pressure was all over the place after the 1000ft mark.
with it everything is ok. i never put one together with out one after that.
Re: do you run a windage tray in your 440? [Re: rickraw] #1148871
01/02/12 07:51 PM
01/02/12 07:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup. If it's the MP part, definitely add some louvers for drain-back. The Milodon tray is better out of the box.
The rotating assy can suck oil up from a fair distance, which then wraps around the crank & rods. As effective as the reciprocating assy is at pumping at the top, it's also pretty effective at whipping & stirring at the bottom.
Re: do you run a windage tray in your 440? [Re: viperblue72] #1148872
01/02/12 08:42 PM
01/02/12 08:42 PM
Locomotion Offline
Locomotion  Offline
Crank is high in the block in a big block but the oil pan tends to be shallower than a small block. As mentioned by others, if you use a tray, use one with as many louvers as possible. If you are considering a crank scraper or combo, check out the options available from Ishihara-Johnson:
Ishihara-Johnson B/RB crank scrapers & trays/screens.
Re: do you run a windage tray in your 440? [Re: Locomotion] #1148873
01/02/12 10:05 PM
01/02/12 10:05 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i cut my windage tray up & made it into a scraper, thought it was a better deal.
Re: do you run a windage tray in your 440? [Re: rebel] #1148874
01/02/12 10:24 PM
01/02/12 10:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have always run one. Ron
Re: do you run a windage tray in your 440? [Re: 383man] #1148875
01/02/12 10:33 PM
01/02/12 10:33 PM
I make my own crank scrapers and use the stock Mopar stock stroke windage trays I open up the louvers on the side for better drain back I do use the two oil pan gaskets bewtween the scraper and windage tray, I cut one in half and glue it on the block up to the crank scraper, the scraper is glue onto the other side of the block and then one thick Fel Pro gasket on top of the scraper and half gasket, another thick Fel Pro between the oil pan and windage tray I have since started adding more drain back holes at every main cap like the one in the picture on the right side, I took this picture before adding those additional holes
Re: do you run a windage tray in your 440? [Re: Locomotion] #1148876
01/04/12 08:28 PM
01/04/12 08:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I installed one from Ishihara-Johnson and it works great.
Nautilus Racing-
Re: do you run a windage tray in your 440? [Re: Chris2581] #1148877
01/05/12 02:21 AM
01/05/12 02:21 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I was always told to run one so every engine I've built has had one, for repair to cost ratio it certainly doesn't hurt to run one.
Mike
1969 Dodge Dart Swinger
Re: do you run a windage tray in your 440? [Re: MikeyT] #1148878
01/05/12 02:52 AM
01/05/12 02:52 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I use Milodon's drag pan..it has a built in windage tray...
Re: do you run a windage tray in your 440? [Re: viperblue72] #1148879
01/05/12 10:31 AM
01/05/12 10:31 AM
an8sec70cuda Offline
Yep, I use one on every BB I build. The Milodon tray is much nicer than the MP tray.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: do you run a windage tray in your 440? [Re: an8sec70cuda] #1148880
01/05/12 10:59 AM
01/05/12 10:59 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
DON'T KNOW where they came from ... I think maybe from a bulk-buy at the Big Daddy meet some years ago ...I have a STACK of used OEM ones. Some are bent in the rail area .. but no problemO.
My next build is going to be a low rpm QUENCH moder for my motorhome ... it will have a tray in it .. ferr sure.
Re: do you run a windage tray in your 440? [Re: dOoC] #1148881
01/05/12 11:10 AM
01/05/12 11:10 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I use the miloden standard stroke one. It seemed to clear my 4.15 stroke crank so I just figured it would be ok.
67' charger 499 RB 10.57 at 127
Re: do you run a windage tray in your 440? [Re: viperblue72] #1148882
01/05/12 12:31 PM
01/05/12 12:31 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I ran the original tray with extra slots added to add drainage. It aint pretty, but its functional. I picked up a 440 source tray that looks like a copy of the Milodon to use in my next engine since it extends to the front of the crankshaft, instead of having that exposed area at the front like the factory tray does.
Re: do you run a windage tray in your 440? [Re: PorkyPig] #1148883
01/05/12 02:16 PM
01/05/12 02:16 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I use the MP tray. I pry'd the drainback slots to be a little bigger.
