Page 1 of 4 1 2 3 4
727 with GV o/d or GM 4l60e (4 speed auto) #1148547
01/02/12 12:48 PM
01/02/12 12:48 PM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
Pros and cons of each?
Thx.
-C
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148548
01/02/12 09:10 PM
01/02/12 09:10 PM
Michigan, USA
Michigan, USA
I thought there would be several opinions on this. Maybe not enough people have had experiences?
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148549
01/02/12 09:43 PM
01/02/12 09:43 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I like GV, if you already have a built trans and good converter you get to keep them. Everything fits good with a mopar trans. Only time I use the OD is when I hit the Highway, I don't do the spilt shifting gears BS.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148550
01/02/12 11:01 PM
01/02/12 11:01 PM
Central NC
gch Offline
gch  Offline
Central NC
Post it over in Q&A and you will likely get more response.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: gch] #1148551
01/03/12 12:17 AM
01/03/12 12:17 AM
Michigan, USA
Michigan, USA
Thanks for the move.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: Azzkikrcuda] #1148552
01/03/12 02:40 AM
01/03/12 02:40 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I have had mine for two years now and love it. My 511 has tonnes of low end torque so I use the over drive anytime I am above 45 mph. If I need to slow down below 1800 rpm I leave the over drive enjaged and put the trans in second gear until I'm back up to speed. I have a manual reverse valve body.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: Dabee] #1148553
01/03/12 03:13 AM
01/03/12 03:13 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I think Stu has the Keisler, ask him.
-Daty
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: Daty Rogers] #1148554
01/03/12 11:40 AM
01/03/12 11:40 AM
Michigan, USA
Michigan, USA
Stu has been in contact with me. I was looking for others that have thoughts as well. Stu has some great info, but just looking for a sample size greater than 1. FYI this is the most helpful Mopar forum website that I have found.
-C
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148555
01/03/12 02:08 PM
01/03/12 02:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Chad,
Check your other thread "anyone have experience with Keisler A41 auto 4spd",...I posted my install critique there
Mike
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: DAYCLONA] #1148556
01/03/12 04:08 PM
01/03/12 04:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The keisler transmission is basically just a GM small block rwd/overdrive transmission. They rebuild em to take some hp. There are some members on here who've installed the chevy transmissions without buying the keisler kit.
Also keep in mind, the overdrive ratio on the gear vendors is basically .8 where the GM transmission and mopar overdrive transmissions are .7 4th gear ratio. Plus those numbers into a calculator like this one and you'll see that makes a sizable difference.
http://vexer.com/automotive-tools/speed-rpm-calculator
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: DaytonaTurbo] #1148557
01/31/12 09:34 PM
01/31/12 09:34 PM
Michigan, USA
Michigan, USA
I am still debating these options and have also learned that the GM trans has a much higher first gear ratio. It is also completely electronic, so it could be run in full auto even though I don't have a kick down option. Is the taller first gear (3.06 vs 2.45 in a 727) a benefit or an issue?
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148558
01/31/12 11:17 PM
01/31/12 11:17 PM
Michigan, USA
Michigan, USA
Any weight savings with either option?
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148559
02/01/12 05:46 AM
02/01/12 05:46 AM
Manitoba, Canada
Manitoba, Canada
You still need to have a kickdown for the transmission. With the 4L60E it is probably a throttle position sensor because the ecu needs some way of knowing how hard you're pressing the gas.
As for the low first gear, well a heavier car and/or a numerically lower rear end gear ratio like a 3.55 or lower will benefit the most from the steeper first gear of the GM trans.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: ramman5600] #1148560
02/01/12 11:19 AM
02/01/12 11:19 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, a 727 with 4.10's out back has an overall first gear multiplication of 10.05 (2.45*4.1)...which is the same overall multiplication as a 4l60E with a 3.28 rear (10.05/3.06)....IIRC OD is .73, so if you used a 3.23 rear with a 4L60E, first gear acceleration the same as a 4.10 with a 727, but OD cruise would be the same as a 727 with a 2.36 rear end....
for a heavy car, I'd think it's a benefit.
2017 Grand Cherokee Overland
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: patrick] #1148561
02/01/12 11:47 AM
02/01/12 11:47 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
How much power does it need to handle? The 700R4 and 4L60E have the steep first gear. Good for trucks, etc.
Look into a well built 200R4. Overdrive without the huge first gear.
The GV makes sense if you already have everything setup and just want a bolt on deal.
383, Hemi 4-Speed, AlterKtion, D60
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: Crazy68Dart] #1148562
02/01/12 11:50 AM
02/01/12 11:50 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just curious, are all G.M. trannies electric. If so how could I make it usable in an older truck? Reason I ask is, there is one laying around here and I would like to use it. Thanks.
I have mechanical Aptitude.
I can screw up anything.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: bboogieart] #1148563
02/01/12 01:35 PM
02/01/12 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you would make it usable the same way you would if you stuck in in a muscle car , with a separate controller.
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: bboogieart] #1148564
02/01/12 01:43 PM
02/01/12 01:43 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Early 700's are not electronic...guys swap them into early GM's pretty often. (my buddy has a '72 C10 with a 700 in it actually..and I had a a similar thing around before as well)
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: DaytonaTurbo] #1148565
02/01/12 02:50 PM
02/01/12 02:50 PM
Michigan, USA
Michigan, USA
I would use the TPS sensor on the 6.1 L for the "kick-down" on the GM trans or a manual Valve body on the 727 and eliminate the kick-down altogether. If I am running 3.73 gears will that first ratio be too steep? It would act like a 727 with a 4.65 geared rear.
-C
Re: 727 with GV o/d or Kieselr A41 (4 speed auto) [Re: Crazy68Dart] #1148566
02/01/12 02:52 PM
02/01/12 02:52 PM
Michigan, USA
Michigan, USA
It needs to handle 550-600Hp in the future. If I already had the 727 I would definitely go the GV route, but I need and entire trans setup. Total cost is slightly in favor of the keisler setup.
Page 1 of 4 1 2 3 4
