Re: Front Fender to Rail,,,,Sealant or "DumDum"?
[Re: TransAm Twins]
#114852
09/03/08 09:39 PM
09/03/08 09:39 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
yes, seam sealer was used.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
[Re: TransAm Twins]
#114853
09/03/08 10:50 PM
09/03/08 10:50 PM
Seam Sealer is not a good choice.It will act as a glue,and make removing the fender extrememly difficult.DumDum would be a better choice as it will seal out the water and mud,but not bond the panels.You could use a butyl in a caulking tube from the hardware store too,as it will flow and never totally hardens.
[Re: cataclysm80]
#114855
09/04/08 08:32 AM
09/04/08 08:32 AM
Posts: 2,304 WI
RestoRick
WI
Imagine driving in a rainstorm... ('ya know, like when these cars were actually driven )... I'd think water & debris thrown around in the fender from the tires would drive through the gap and have it's way with wiring, electrical connections, etc. And yes, rust too, from schmuck building up under the flange. Anti-squeak possibly too? Rick
[Re: RestoRick]
#114856
09/04/08 11:00 AM
09/04/08 11:00 AM
Posts: 232 Ft. Worth, TX
TransAm Twins
Ft. Worth, TX
Thanks for the responses. Will make sure we put something resiliant under the fenders. Rick, the "quasimoline" came out just fine. Ken
