Dodge Dakota Race Truck #1148404
01/01/12 11:26 PM
01/01/12 11:26 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anyone race a Dakota? How do i get some weight off of the front end? It is a 1988 model with a small block. Anyone make fiberglass parts for an 88? Thanks
Re: Dodge Dakota Race Truck [Re: bobs69] #1148405
01/01/12 11:34 PM
01/01/12 11:34 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
I cut the core support up.Their is really nothing that heavy up front.I made my hole front end come off as one.Maybe 125 lbs.
Re: Dodge Dakota Race Truck [Re: 8secDart] #1148406
01/02/12 11:39 AM
01/02/12 11:39 AM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
the only thing in fiberglass,i have seen is a hood.i have an 88 dakota street/strip weighs 3370 race weight.that weight is with a 340 stroker/ 727 / 8 3/4.
Re: Dodge Dakota Race Truck [Re: hp340nos] #1148407
01/02/12 12:02 PM
01/02/12 12:02 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I too have not seen any early dakota fiberglass parts except hoods. A one piece front end would be nice.
I have mine down to about 3300 also with no bumpers an gutted interior
95 dakota 440/727/8.75
Re: Dodge Dakota Race Truck [Re: sturmenater] #1148408
01/02/12 06:12 PM
01/02/12 06:12 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
AAR used to make a fiberglass front bumper ,I had one on
my 87 ,with aluminum bracket's it was a lot lighter.
Maybe they can still make one up for you ??? But It's not
listed on there site ...
Hey 8secDart ,what did you cut off your core support?
Or what else did you do to get weight of the front..
any pic's ?
Re: Dodge Dakota Race Truck [Re: 87MO DAK] #1148409
01/03/12 12:04 AM
01/03/12 12:04 AM
8secDart Offline
8secDart  Offline
Here is some pictures.Mine is far from light.3,250lbs but the front end is not heavy.
Re: Dodge Dakota Race Truck [Re: 8secDart] #1148410
01/03/12 12:20 AM
01/03/12 12:20 AM
8secDart Offline
8secDart  Offline
Here is a few more!!
Re: Dodge Dakota Race Truck [Re: bobs69] #1148411
01/03/12 04:47 PM
01/03/12 04:47 PM
ccarson Offline
ccarson  Offline
I was hoping to get my on going 93 Dakota project under 3000#
Small Block Aluminum W9 Heads,full roller 727 and 9"
I have the AAR Hood, Front Bumper and Roll Pan
I also Cutoff the core support and got busy on it with a hole saw 2,3 an 4"
Gutted the interior, putting the stock dash shell and interior panels and headliner back in, It just looks better.
I havent sectioned the front crossmember yet but it looks like a good place to remove some weight.
Re: Dodge Dakota Race Truck [Re: ccarson] #1148412
01/03/12 05:53 PM
01/03/12 05:53 PM
Oklahoma City, Oklahoma
DusterDj Offline
DusterDj  Offline
Very nice work...
https://www.facebook.com/dusterdj572 Check out my race page and like please.
Re: Dodge Dakota Race Truck [Re: 8secDart] #1148413
01/03/12 07:46 PM
01/03/12 07:46 PM
Indiana
SB Dakota Offline
SB Dakota  Offline
Indiana
WOW that one sweet and awsome ride.... LOVE IT..
i never thought of taking some meat off the front end.
Larry Anderson 87 Dodge Dakota 416 Stroker 71 Dodge Dart http://i58.photobucket.com/albums/g254/rules371/88888888888-1.jpg
Re: Dodge Dakota Race Truck [Re: bobs69] #1148414
01/03/12 10:14 PM
01/03/12 10:14 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
You can get a fiberglass hood is all for the front end. My 88 Dakota weighed in at 3150 lbs with me in it and I weight 170 lbs fully suited up. No real weight taken out of the truck, except all the under dash wiring and instruments, and rear bumper.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: Dodge Dakota Race Truck [Re: sc4579] #1148415
01/04/12 10:09 PM
01/04/12 10:09 PM
ccarson Offline
ccarson  Offline
Thats good news is that BB or SB
Re: Dodge Dakota Race Truck [Re: ccarson] #1148416
01/05/12 12:30 AM
01/05/12 12:30 AM
ms
W
w2dak394 Offline
w2dak394  Offline
W
ms
88 model, 3000 lbs. with 270 lb. driver, truck weight is 2720, 12 pt cage, W2 headed small block, 904 trans, 9" rear. Up front cut inner fenders out, cut hood braces off, remove hinges, remove metal under cowl, trim k member just like previous pictures from another poster, 2" lowering spindels, removed alot on core support, removed headlights and all hardware, remove hood latch, cut bottom half of frame rails (from bumper brackets to were roll bars attach), aftermarket steering colum, stock brakes, factory bumper, weld wheels, front runners, stock radiator. Cab mods, glass windshield, all others are lexan, doors gutted exceptlatch and latch handels, alum dash, one race seat, no headliner, no carpet, no factory dash. Rear, stock leaf springs, no tailgate, no bumper, weld wheels.
Re: Dodge Dakota Race Truck [Re: w2dak394] #1148417
01/05/12 08:14 PM
01/05/12 08:14 PM
WI
68hemiss Offline
68hemiss  Offline
WI
Guys,
Could you post some pics of your Dakotas - I have a friend who is contemplating building a smallblock Street/Strip Dakota. Drop front spindles or not? Wants to see how they look vs. std ride height.
Thanks!
Re: Dodge Dakota Race Truck [Re: 68hemiss] #1148418
01/05/12 09:29 PM
01/05/12 09:29 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
Guys,
Thanks!
I have refrained from posting because mine is a different body style from the OP.
I can tell you what I did to get my front end down. I cut the dodge control arms and cut/welded S-10 control arms to the dodge control arms, moving the tires inboard 2" each and setting my caster too 7 degrees. Some of the issues I ran into are, need lighter springs, need to scollop the frame for control arm clearance, must use S-10 tie rod ends, etc. Sorry, I don't have any pics on my computer at this time.
Re: Dodge Dakota Race Truck [Re: 68hemiss] #1148419
01/06/12 01:29 AM
01/06/12 01:29 AM
8secDart Offline
8secDart  Offline
Yes you need drop spindles.Looks like Chit if not!!! You can cut a 1/4 round out of the stock 4cyl srings and get away with it.I have drop pockets on my lower arms but there are coming off and drop spindles are going on.
Re: Dodge Dakota Race Truck [Re: challenger73400] #1148420
01/06/12 01:45 AM
01/06/12 01:45 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
challenger73400....Love your truck, mine is the same body style. Here's a pic with it dropped 1" front and back...Monoleafs and Caltracs w/ 1" blocks. I'd like to go lower, but it hooks so well I hate to mess with it...
Re: Dodge Dakota Race Truck [Re: 68hemiss] #1148421
01/06/12 02:31 PM
01/06/12 02:31 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
Guys,
Thanks!
Here is my 88 with a 402 small block that ran 7.0's in the 1/8 all day in the TX heat. Ladder bars, 8 pt cage, stock front suspension. Just sold it today to a guy in Arkansas.
2016 Jeep Renegade
Re: Dodge Dakota Race Truck [Re: Adobedude] #1148422
01/06/12 11:57 PM
01/06/12 11:57 PM
southwest Alabama
southwest Alabama
Thanks! Yours looks great! Forgot to mention I also used 2" drop spindles.
Re: Dodge Dakota Race Truck [Re: challenger73400] #1148423
01/07/12 09:40 PM
01/07/12 09:40 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
Here is how mine sits i cut a full coil of 80 chevy 2wd 1 ton springs.
I cant go much lower with out smaller front tires or different headers the hooker a body fenderwells rub if i turn more than 3/4 of the way.
