Re: Dodge Dakota Race Truck
[Re: 8secDart]
#1148413
01/03/12 07:46 PM
01/03/12 07:46 PM
Posts: 56 Indiana
SB Dakota
Indiana
Here is a few more!!
WOW that one sweet and awsome ride.... LOVE IT.. i never thought of taking some meat off the front end.
[Re: bobs69]
#1148414
01/03/12 10:14 PM
01/03/12 10:14 PM
Posts: 852 Georgetown, TX
sc4579
Georgetown, TX
You can get a fiberglass hood is all for the front end. My 88 Dakota weighed in at 3150 lbs with me in it and I weight 170 lbs fully suited up. No real weight taken out of the truck, except all the under dash wiring and instruments, and rear bumper.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
[Re: ccarson]
#1148416
01/05/12 12:30 AM
01/05/12 12:30 AM
Posts: 86 ms
w2dak394
ms
88 model, 3000 lbs. with 270 lb. driver, truck weight is 2720, 12 pt cage, W2 headed small block, 904 trans, 9" rear. Up front cut inner fenders out, cut hood braces off, remove hinges, remove metal under cowl, trim k member just like previous pictures from another poster, 2" lowering spindels, removed alot on core support, removed headlights and all hardware, remove hood latch, cut bottom half of frame rails (from bumper brackets to were roll bars attach), aftermarket steering colum, stock brakes, factory bumper, weld wheels, front runners, stock radiator. Cab mods, glass windshield, all others are lexan, doors gutted exceptlatch and latch handels, alum dash, one race seat, no headliner, no carpet, no factory dash. Rear, stock leaf springs, no tailgate, no bumper, weld wheels.
[Re: 68hemiss]
#1148418
01/05/12 09:29 PM
01/05/12 09:29 PM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
Guys, Could you post some pics of your Dakotas - I have a friend who is contemplating building a smallblock Street/Strip Dakota. Drop front spindles or not? Wants to see how they look vs. std ride height. Thanks!
I have refrained from posting because mine is a different body style from the OP. I can tell you what I did to get my front end down. I cut the dodge control arms and cut/welded S-10 control arms to the dodge control arms, moving the tires inboard 2" each and setting my caster too 7 degrees. Some of the issues I ran into are, need lighter springs, need to scollop the frame for control arm clearance, must use S-10 tie rod ends, etc. Sorry, I don't have any pics on my computer at this time.
[Re: Adobedude]
#1148422
01/06/12 11:57 PM
01/06/12 11:57 PM
challenger73400
southwest Alabama
challenger73400....Love your truck, mine is the same body style. Here's a pic with it dropped 1" front and back...Monoleafs and Caltracs w/ 1" blocks. I'd like to go lower, but it hooks so well I hate to mess with it...
Thanks! Yours looks great! Forgot to mention I also used 2" drop spindles.
