Splitting seam on outer wheel well?
#1148183
01/01/12 05:39 PM
01/01/12 05:39 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
What is the best method to split the seam on the wheel well? Going to be replacing the outer wheel wells on my charger.
Thanks.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Splitting seam on outer wheel well?
[Re: yellowfin]
#1148185
01/02/12 06:30 AM
01/02/12 06:30 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Like said,,, if plug welding the new, just drill out the old. If spotting or plugging from the inside, I always used a cut off wheel to grind the spot weld from the inside. Keeps the quarter untouched if you're careful.
Chris from New Jersey
[Re: fig426]
#1148186
01/02/12 03:30 PM
01/02/12 03:30 PM
69charger440_6pa
Oakley CA
Sorry should have been more clear. I'm not talking about the seam on the quarter. I'm taking about the seem for the 2 halfs of the wheels wells. It's not exactly spot welded like everything else on the car is.
[Re: 69charger440_6pa]
#1148187
01/02/12 08:32 PM
01/02/12 08:32 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
They aren't ???
[Re: Dodge33]
#1148189
01/03/12 01:30 AM
01/03/12 01:30 AM
JohnRR
U.S.S.A.
they are what I CALL roll welded,put in a machine and welded with electric current.you have to cut the metal outer wheel well off,leave the flat of the outer well on there,take a grinder carefully grind the flat flange away. hint when the metal gets thin and turns blue STOP, use a pair of plier's and wiggle the thin metal loose,use a 3 or 4 inch pad grinder to finish,go slow not to make the inner flange thin.
Thanks , I didn't know that , I'll have to look at one closely now ...
