Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148030
01/02/12 11:47 AM
01/02/12 11:47 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Why would you not, or did you not trust the advice from the shop doing the work? They should have had good sound advice on the topic.
RIP Monte Smith
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148031
01/03/12 01:37 AM
01/03/12 01:37 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Change of Subject Whose air pan base are you using and where did you buy it? I noticed it's the same as the guy in Arizona who rebuilt his Cuda. Thanks, Dave A
