Indy Heads ?? Is Head Bolts / Or Studs #1148010
01/01/12 12:58 PM
01/01/12 12:58 PM
Super Scamp Offline OP
Gentalmen,
My heads are getting work done by the BEST shop around and I want to install them with the Best Bolts or Studs.. What do you use on your heads.
I'm looking into a stud kit from APR.
Just One Man's Opinion Mopar Mafia Racing
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148011
01/01/12 01:06 PM
01/01/12 01:06 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Gentalmen,
I used the Manley bolts that came with the heads just in case I need to pull the heads in the car,lots easier with bolts
Gus
64 Plymouth Savoy
Dana 60
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148012
01/01/12 01:08 PM
01/01/12 01:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think a lot of replies will say that it depends on the use of the motor. However, studs are more of a pain when installing or removing a head. It will also depend on which heads you have and which headers you're using as to whether they will clear the studs.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: fourgearsavoy] #1148013
01/01/12 01:10 PM
01/01/12 01:10 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
ARP studs have a hex in the top of the stud so you can pull them out with the head on the block. I would use studs for the increased clamping force.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Stanton] #1148014
01/01/12 01:14 PM
01/01/12 01:14 PM
440-1 with 2" step headers In a A body Not easy to get at the bolts for sure??
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148015
01/01/12 01:55 PM
01/01/12 01:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Since most Indy heads only require 70 lbs ft torque the Manley bolts are fine,in max hp/compression applications we recommend head studs.So if your not exceeding 700hp and 13/1 CR we would use the bolts.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148016
01/01/12 02:29 PM
01/01/12 02:29 PM
So BG use Manley bolts Ok not APR? I'm also switching gaskets, Was running Fel-Pro 1105 039 Moving to Clark setup? What you think.
Motor is 12.8 to 1 and 518" T&D rocker setup.1.5 This combo is a flat tappit roller setup.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148017
01/01/12 03:15 PM
01/01/12 03:15 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
ARP BOLTS
440-1s CNC 345,s
13.1 comp
1.39 9.85 - 137 mph
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148018
01/01/12 03:18 PM
01/01/12 03:18 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
everyone has opinions mine is that bolts should not be used in main cap, cylinder head or rocker gear attachment. every time you pull up on a bolt it damages the threads especially in aluminum heads. i would never use bolts on the rocker gear of an aluminum head even if it has some type of insert. i've just seen too many aluminum heads with damaged threads. studs also offer more effective clamping.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: jamesc] #1148019
01/01/12 03:41 PM
01/01/12 03:41 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
case closed.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: rickraw] #1148020
01/01/12 03:51 PM
01/01/12 03:51 PM
case closed.
OK Boys Agreed Studs (APR/Manley) it will be. Now For the ? I asked BG What Head gasket....
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148021
01/01/12 04:01 PM
01/01/12 04:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
case closed.
Fel-Pro performance gaskets are fine for your application,Cometics are great but not necessary.When you say Clarke,are you talking copper?
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148022
01/01/12 04:21 PM
01/01/12 04:21 PM
Yes!!
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: Super Scamp] #1148023
01/01/12 08:08 PM
01/01/12 08:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Unless your o-ringing the heads and reciever groving the block deck,I would not recommend copper head gaskets.We have gone to Cometic head gaskets in any application over 14/1CR and use them on our blower engine.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148024
01/01/12 08:13 PM
01/01/12 08:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
case closed.
OK Boys Agreed Studs (APR/Manley) it will be. Now For the ? I asked BG What Head gasket.... [/quot
I'm pirating the post. Bob what gaskets for 15--1? What torque do you recommend on the studs? I'll say in advance my -1s are milled down to 57cc.
Thanks Doug
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: dvw] #1148025
01/01/12 08:25 PM
01/01/12 08:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Doug,
We use Cometics on most all our 14/5 and 15/1 combos.We generally spray them with copper coat and torque 7/16 studs and bolts at 75# and 1/2 studs and bolts at 85#.We also put a skim coat of ultral copper around and water passages if necessary,we use ultra copper on the water passages on all copper/o-ringed applications.These torque specs are with molylube.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148026
01/01/12 08:27 PM
01/01/12 08:27 PM
jamesc Offline
jamesc  Offline
BG have you used any SCE gaskets, specifically the Titan ICS
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148027
01/01/12 08:44 PM
01/01/12 08:44 PM
Thank's BG and others for the quick on-line help. I will order Fel-Pro again.Waiting to see how much is being cut on the heads then I will order gaskets.
This is Official It's all about Gaskets now...
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: jamesc] #1148028
01/01/12 08:45 PM
01/01/12 08:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Yes,we have in the past and found the ones that came coated didn't seal well and some were very hard.We usually cleaned them with acid or other cleaners and heated them to get them to anneal and take seat at the o-rings.The softer the copper the better the seal.
Re: Indy Heads ?? Is Head Bolts / Or Studs [Re: B G Racing] #1148029
01/02/12 10:57 AM
01/02/12 10:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug,
Thanks Bob. I'll see about getting that Icon for you.
Doug
