Thrust bearing/crank failure #1147988
01/01/12 11:47 AM
01/01/12 11:47 AM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
I posted a month ago about an end play problem with my 440. I tore it down yesterday the block looks OK so far. I still need to tear it down the rest of the way and see if the debris left scratches and such.
Here's a pic showing the thrust bearing and the grove cut into the crank:
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1147989
01/01/12 11:51 AM
01/01/12 11:51 AM
Can you see any protrusion that was cutting that groove
Re: Thrust bearing/crank failure [Re: RapidRobert] #1147990
01/01/12 12:13 PM
01/01/12 12:13 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I feel your pain. I just went thru 2 small blocks 318 and 360 that did the same in my 84 d150. The only reason I could come up with as to a cause is the torque converter "balloning" when I was pulling a load. I was able to find a replacement crank cheap in both cases.I did talk to a crank grinding place about it and they said that the cranks could be welded and resurfaced so if yours is a steel crank it may be a way to recover it.
Re: Thrust bearing/crank failure [Re: mod5v] #1147991
01/01/12 01:56 PM
01/01/12 01:56 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
A problem I have read about on another site was the crank thrust surface finish was not smooth enough causing excessive ware. I dont think many machinist really look at that surface at all when they polish/refinish a crank. This a a prob with many 5.0 ford racers from what I have read. They resolved the prob by using a much finer polished finish on the thrust surface. Is it a 4sp or auto?? Another 440 locally here had the same problem after a few hundred miles. Let us know what your machinist says.
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1147992
01/01/12 09:10 PM
01/01/12 09:10 PM
I don't remember your former post, how much end play, in thousands, do you have now? Was it checked before running the motor and if so how much was it originally? Last question, do you know now why it became a problem? If not find and correct that problem before running the motor after you fix it
Re: Thrust bearing/crank failure [Re: Cab_Burge] #1147993
01/02/12 02:38 PM
01/02/12 02:38 PM
74RALLYE Offline OP
74RALLYE  Offline OP
I can't say what the end play was after it was built, but 3/16" was where it ended up. In the picture you can see a groove in the crank thrust face that should not be there. The bearing has metal galled up on the inside radius and the surface is way gone.
I have another crank. The machinist said to bring it over with the other parts of the rotating assembly for a balance job. Also said the block would need cleaning to get the bearing material out.
While I’m at it, I’m going to swap out the automatic trans and put in a 4sp.
My computer took a dump over the holidays so I'm a little slow getting back sometimes.
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1147994
01/02/12 06:04 PM
01/02/12 06:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You picture is blurry , what crank is that ?
Re: Thrust bearing/crank failure [Re: JohnRR] #1147995
01/02/12 07:42 PM
01/02/12 07:42 PM
74RALLYE Offline OP
74RALLYE  Offline OP
It's a cast 440 crank. Here's a better pic of the crank wear. The groove should be a flat surface.
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1147996
01/02/12 07:44 PM
01/02/12 07:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
link no worky
Re: Thrust bearing/crank failure [Re: JohnRR] #1147997
01/02/12 07:53 PM
01/02/12 07:53 PM
74RALLYE Offline OP
74RALLYE  Offline OP
And another:
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1147998
01/02/12 08:22 PM
01/02/12 08:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
first thing I see is you have a wide thrust crank and a narrow thrust main , the more surface area on the main the better .
Now what caused that , is that on the front or the rear of the bearing thrust ?
I don't remember your application , 4 speed or auto ? Race ?? Nitrous ??
Re: Thrust bearing/crank failure [Re: JohnRR] #1147999
01/02/12 09:18 PM
01/02/12 09:18 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
A cast crank should definitely have the wide flange thrust bearing to reduce the wear on the crank. The '74 and later blocks used the larger thrust bearing, but it looks like you have the smaller bearing in your engine. It's VERY important that the thrust bearing main cap is aligned/set during assembly, too. Make sure you're good as far as a pilot bushing if you're going to put a 4 speed behind a cast crank.
Re: Thrust bearing/crank failure [Re: BLACKHEMIRR] #1148000
01/02/12 09:48 PM
01/02/12 09:48 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Narrow flange bearing ate the wide flange crank! Now I've learned something new. Thanks!
I wonder what the chances of this happening with the correct thrust bearing installed?
The damage is on the rear thrust side. It was connected to an auto trans. The motor has 1,000 miles or less. I've never had it on the track, but I do like to accelerate at WOT when I have the space. The only questionable incident I can think of is when I hit a small patch of mud and lost traction.
The replacement crank is steel.
Re: Thrust bearing/crank failure [Re: 74RALLYE] #1148001
01/02/12 10:20 PM
01/02/12 10:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is only a few things that can cause that...
lack of end play when it was assm, burr on the crank,
or and most likely your converter is ballooned...
if you measure the front and the rear sides of the
thrust bearing you will get a idea of how much wear
there is on the rear(within reason) but with all the
wear being on the rear something was pushing the crank
forward.. and that is usually the converter... when
you un-bolted the converter how much did it slide
rearward... I would still measure the converter to
see where the snout is in relation to the pump hub
Re: Thrust bearing/crank failure [Re: MR_P_BODY] #1148002
01/02/12 10:31 PM
01/02/12 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Besides what the guys are saying about the wide vs narrow
bearing I swear that in the first pic the left side
has way more wear than the right side BUT that may be
the pic or angle of the pic
Re: Thrust bearing/crank failure [Re: MR_P_BODY] #1148003
01/03/12 03:10 AM
01/03/12 03:10 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
When you are putting it back together [with the wider bearing] file a chamfer on the parting line of one of the bearing shells to pressure feed oil from the bearing oil groove to the thrust surface, every little bit helps.
