My engine is seeping oil from around the header flanges and bolts and I am guessing the header bolts holes go into the oil gallery. Can someone confirm this for me? Do all the header bolt holes go into the oil gallery or only some? These are the MP aluminum heads.
The car is fabricated and the engine compartment is jammed with stuff otherwise I would just pull the bolts and put sealer on them...thanks for any help
