68-70 B body subframe connectors #1147876
01/01/12 12:53 AM
01/01/12 12:53 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I want to put subframe connectors in The Charger and want to get a few opinions on my options. I've made and welded them in 2 A body cars using 3x3 .120 wall tubing. I cut them to the contours of the floorpan and then REboxed the sections where they were cut away. The Charger front frame rails run at an angle towards the torsion bar crossmember, so I plan to simply run the connectors in a straight line from the rear frame rails forward as I have seen elsewhere. The rear frame rails appear to be 2 1/2" wide, so the 3x3 tubing may also work here. I have seen some ads with connectors that are "Laser Cut" to match the floorpan, but it seems to me that there is probably more stiffness with a boxed connector rather than a 3 sided one.
Opinions?
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147877
01/01/12 01:07 AM
01/01/12 01:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your strongest frame connector will be a rectangular box iron with 4 sides, with the widest beam side being vertical with the other frame members in the vehicle, if cutting the floors doesn't bother, then cut the floors so that the connector protrudes thru the floor, once welded from both sides, they will appear as the laser cut floor matching units sold, only stronger, you could easily fit 2X3 or 2X4 inch box iron connectors doing it this way
Re: 68-70 B body subframe connectors [Re: DAYCLONA] #1147878
01/01/12 03:16 AM
01/01/12 03:16 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Do you have inboard springs? I like the way the Hotchkis connectors are, but make my own.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: 68-70 B body subframe connectors [Re: HUSTLESTUFF] #1147879
01/01/12 03:30 AM
01/01/12 03:30 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
My springs are in the stock location. My thoughts are to fab up the connectors similar to these that I made:
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147880
01/01/12 03:43 AM
01/01/12 03:43 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I also intend to make some Torque boxes and weld them in afterwards. I was just curious as to what other members have done.
Dayclona: Am I to understand that the strength in the connectors is greater in the VERTICAL plane, I.E. in the case of a 2x3 member, the 3" section being vertical? If so, this is the same principle that all truck and car frames share, boxed or open. Curious though since I've never seen these cars sag in the middle like an overloaded burro. (Strange reference, I know) I thought that the intended gain was to resist twisting in the middle, and the welded connectors are a big help in reducing the deflection between the front and the rear. I have seen cars with bolted connectors that are installed with the wider section in the horizontal plane and wondered if they were effective at all.
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147881
01/01/12 08:00 AM
01/01/12 08:00 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Here's my take. For cars with stock spring hangers the loads are being transmitted at that location. That is why Chrysler made torque boxes, to connect the thrust to the frame rails. By using the Hotchkis style, you are strengthening the unibody in the right areas and eliminating the need for torque boxes. For cars with inboard springs (in the framerails) putting the connectors in line with the rear frame rails does the same thing. I believe that on most cars the spring hangers line up with the front frame rais as well.
RIP UN
Re: 68-70 B body subframe connectors [Re: HUSTLESTUFF] #1147882
01/01/12 01:04 PM
01/01/12 01:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you fastened pieces of 2 x 4 lumber in there it would still be an improvement. I've seen guys use single round tubes, double smaller round tubes, 1 x 2 cold rolled rec. tubing , 2 x 2 square and 2 x 3 rec. as well as the laser cut stuff. When you get up to 2 x 2 square, 2 x 3 rec. or the laser cut pieces you'd have a hard time telling the difference unless it were a full-time drag or autocross car - in which cas you'd probably have a bit more tubing inside helping to keep things from twisting.
Re: 68-70 B body subframe connectors [Re: Stanton] #1147883
01/01/12 05:07 PM
01/01/12 05:07 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I was curious about the engineering aspect. I figured that at some point the larger sized connectors would be an issue of diminishing returns. The reduced ground clearance and ugly non stock appearance wouldn't be worth the minor additional gain.
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147884
01/11/15 06:53 AM
01/11/15 06:53 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I did go ahead and weld in the 3x3 frame connectors and torque boxes. The car handled great before but afterward, the ride felt more solid. The car soaked up dips and bumps with fewer rattles. It was quieter. I fully endorse this upgrade to anyone except those with OEM correct restorations.
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147885
01/11/15 06:56 PM
01/11/15 06:56 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Pics if ya got any. i'm looking to do this when it warms up on my RR
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147886
01/11/15 07:15 PM
01/11/15 07:15 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I had a local shop fabricate some for the road runner and they did make a difference on how the car rides and reduced squeaks.
Re: 68-70 B body subframe connectors [Re: mikemee1331] #1147887
01/19/15 01:48 AM
01/19/15 01:48 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Pics if ya got any. i'm looking to do this when it warms up on my RR"
I was finally able to take some pictures.
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147888
01/19/15 01:49 AM
01/19/15 01:49 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147889
01/19/15 01:51 AM
01/19/15 01:51 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147890
01/19/15 01:52 AM
01/19/15 01:52 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147891
01/19/15 01:54 AM
01/19/15 01:54 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Re: 68-70 B body subframe connectors [Re: Kern Dog] #1147892
01/19/15 01:55 AM
01/19/15 01:55 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
