grease pencil numbers on valve covers #1147849
12/31/11 11:30 PM
12/31/11 11:30 PM
PA
Y
yellowfin Offline OP
Y
PA
Seen alot lately - But did the 68's have them also? Restoring my 68 GTX, and found none, but they had been spray bombed before, and any numbers(if any) were probably lost. If so, what would the numbers have been, and exactly where on the cover? Also, what colors were used? Any pics from the same time frame (SPD of 5-24-68 @ St. Louis plant)would be great. Thanks
Re: grease pencil numbers on valve covers [Re: yellowfin] #1147850
01/01/12 01:38 AM
01/01/12 01:38 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
My 68 RR has marking on the right cover facing alt. My car is a st louis car with a 5/21/8 spd. Sorry no pics right now as I am moving and pc is down right now. I should be able to post some in the next week.
Re: grease pencil numbers on valve covers [Re: rrunner] #1147851
01/01/12 03:51 AM
01/01/12 03:51 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, one cover has the engine code and the other the trans code. I've seen Hemis in white or yellow, wedges in black.
Re: grease pencil numbers on valve covers [Re: rrunner] #1147852
01/01/12 10:47 PM
01/01/12 10:47 PM
PA
Y
Y
PA
RRunner, those pics would be awesome. No hurry, just get to them whenever you can. BTW, if you're moving, stay down south - I'm up north and you don't want what we have up here(not to mention all the salt on the roads). In the meantime, did the numbers correspond to the engine code and in what color? With a SPD that close to mine, I would feel pretty confident that my 'X would have had them applied as well. Anyone know what the engine code was for a HP 440 in '68? Fender tag code was an 83, but isn't this different than the engine code on the build sheet? Which one did they use? I have only fragments of the build sheet (found in a mouse nest inside the console)and unfortunately it didn't include that specific part. As for the trans code, where was this applied and what was it for an automatic?
Re: grease pencil numbers on valve covers [Re: yellowfin] #1147853
01/11/12 01:18 PM
01/11/12 01:18 PM
PA
Y
Y
PA
In the meantime, anyone else care to chime in with their own observations? Even all you charger/coronet/superbee folks should have input as to what is found on the valve covers of you engines, be it the 383 or 440 versions. So lets have it, what was the protocol for these numbers on all the '68 valve covers at the St. Louis plant?
Re: grease pencil numbers on valve covers [Re: yellowfin] #1147854
01/11/12 02:44 PM
01/11/12 02:44 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Here is mine from the original engine 383 71 Road runner.
The 419 matches to the broadcast sheet the 25 still working on.
Re: grease pencil numbers on valve covers [Re: farmboy70] #1147855
01/11/12 02:47 PM
01/11/12 02:47 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Sorry didn't see the 1968 part.
Re: grease pencil numbers on valve covers [Re: farmboy70] #1147856
01/11/12 08:49 PM
01/11/12 08:49 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a 68 383 auto....Nothing on the left valve cover...
Re: grease pencil numbers on valve covers [Re: yellowfin] #1147857
01/11/12 11:16 PM
01/11/12 11:16 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
Just realized that I have never seen these markings on small blocks. Was this strictly a big block and/or a plant specific deal?
Re: grease pencil numbers on valve covers [Re: TransAm Twins] #1147858
01/11/12 11:44 PM
01/11/12 11:44 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
maybe in particular 71 340
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
