2003 jeep grand cherokee problem #1147750
12/31/11 07:47 PM
12/31/11 07:47 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline OP
this jeep has wicked tail wag at any speed over 50mph. was never hit or rusty. anyone have this effect on thier jeep grand?
MOPAR OR NO CAR
Re: 2003 jeep grand cherokee problem [Re: hemigod426] #1147751
12/31/11 08:50 PM
12/31/11 08:50 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Put the car on a lift with the rear suspension hanging and check for broke or loose suspension parts. Pump up the rear tires more?
Re: 2003 jeep grand cherokee problem [Re: rapom] #1147752
12/31/11 10:23 PM
12/31/11 10:23 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Also check the tires for broken belts.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 2003 jeep grand cherokee problem [Re: johnedod] #1147753
01/01/12 12:15 AM
01/01/12 12:15 AM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Something is disconnected,broken,or sheared off.Mine has 138,000 and goes straight as an arrow at 90mph.
Re: 2003 jeep grand cherokee problem [Re: Geezer] #1147754
01/01/12 01:42 PM
01/01/12 01:42 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
i would check the mounts and the ball joint on the upper A arm for the rear suspension.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 2003 jeep grand cherokee problem [Re: ViperDave] #1147755
01/01/12 03:01 PM
01/01/12 03:01 PM
was thinking its a problem in 3 link rear, was hoping rear lower trailing arms were shot(easy to change) making axle wiggle so much, jeep has 150k miles on it, was trading into local dodge dealer because of this, i bought it from them(cheap) because it looked so nice.
MOPAR OR NO CAR
Re: 2003 jeep grand cherokee problem [Re: hemigod426] #1147756
01/02/12 09:23 PM
01/02/12 09:23 PM
got it in the shop everything looked good attached to rear axle, put small pry bar between axle/arm and frame mount and front of trailing arm. they had 1 inch of play with no weight on axle, thats why axle felt like it was gunna fall out.the drivers side arm in pic the bushing fell right out when arm removed. sold the jeep needed parts fast bought set from jeep dealer ouch 230. my cost 320. regular cost. all tight back there now at speed
MOPAR OR NO CAR
