Whoa! Problem #114722
09/03/08 05:02 PM
09/03/08 05:02 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Stock '66 Chrysler 300. 383/727 carter AFB #4131S
Drove it round a bit today up and down some hills, kind of warm outside.
When I shut off the ignition, it backfired through the carb about 3 times in quick succession, ending with a nasty whizzing sound and a puff of smoke from under the hood (ka-chunk ka-chunk ka-chunkwhizzzzzzzzz). Now it runs like crap and the power brakes don't work. I have to stand on both the main and parking brake pedals to stop the car. Any ideas on what happened and how to fix it?
-Chris
Re: Whoa! Problem [Re: jeebis44] #114723
09/03/08 05:04 PM
09/03/08 05:04 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Have you checked the vacuum lines.
maybe a split in the vacuum line from carb to booster.
Check the PVC and that vacuum line aslo.
Re: Whoa! Problem [Re: cyphre666] #114724
09/03/08 05:18 PM
09/03/08 05:18 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
vacuum lines look good. Could I possibly have blown the diaphragm in the power brake booster? Has this ever happened to anyone?
Re: Whoa! Problem [Re: jeebis44] #114725
09/03/08 05:31 PM
09/03/08 05:31 PM
I'm wondering if the backfire(s) fried the check valve in the booster.
Re: Whoa! Problem [Re: RapidRobert] #114726
09/03/08 06:03 PM
09/03/08 06:03 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Check the second nipple on the booster. It should have a cap on it unless you have cruise control.
Re: Whoa! Problem [Re: Jim_Lusk] #114727
09/03/08 07:02 PM
09/03/08 07:02 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Ok. Thanks for the help guys. I looked at the check valve and it was indeed broken- backfire blew the entire top off, but it looks like the rubber valve is intact. I think I'll just RTV it back together for now. Anyone know where I can find a new valve though? Anyone know of a specific part part number or what to spec at the parts store or will I just have to jury rig it?
-Chris
