starting problem #114695
09/03/08 03:55 PM
09/03/08 03:55 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
69 Road runner 383. I am looking for a confirmation. 1 out of 20 times, when I go to start the car, I turn the key and absolutely nothing. No clicking, no cranking, nothing. Lights work and it is a new battery. I can bridge the starter relay and with the key on, it will start. What do my expert freinds think the problem, and the cure is to this. FYI relay and the complete motor are new (less than a 500 miles on everything)
Re: starting problem [Re: TrueTripleX] #114696
09/03/08 05:00 PM
09/03/08 05:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Check thr bulkhead connector.
Re: starting problem [Re: 62maxwgn] #114697
09/03/08 05:40 PM
09/03/08 05:40 PM
Silicon valley
A12bee Offline
super street
A12bee  Offline
super street
Silicon valley
check the neutral safety switch.
This space left intentianlly blank.
Re: starting problem [Re: TrueTripleX] #114698
09/03/08 05:54 PM
09/03/08 05:54 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What they said.
You can ground the starter relay to eliminate the neutral switch.
This should be in question and answer section.
Re: starting problem [Re: TrueTripleX] #114699
09/03/08 05:55 PM
09/03/08 05:55 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
Sounds like a bad starter relay.
Is it a 4 speed or auto?
Re: starting problem [Re: Scatransit] #114700
09/03/08 07:40 PM
09/03/08 07:40 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
You have a bad connection in the heavy hot wire at one of the connectors. I had the same problem w/ my Challenger. Tore my hair out till I noticed a black spot in a connector one day. Clip the wires and bypass the connector or pull the wires out and put new ends on them. It will be like a new car.
Re: starting problem [Re: TrueTripleX] #114701
09/03/08 09:39 PM
09/03/08 09:39 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Is it in P or N when it fails to start? My car does that intermittently in park, but if I move it to neutral it starts every time. I just start it in neutral now. If I ever get stranded i'll ground the neut. safety switch to start it.
