Re: Garage Exhaust Hose for Fume Control
[Re: Quicktree]
#1146923
12/30/11 05:23 PM
12/30/11 05:23 PM
Posts: 2,333 Kalamazoo, MI
StrokedW7
Kalamazoo, MI
Garage door works fine for me
You wouldn't say that if you lived in Michigan in the middle of January...
[Re: StrokedW7]
#1146924
12/30/11 05:27 PM
12/30/11 05:27 PM
Quicktree
thats why I don't live there
[Re: StrokedW7]
#1146927
12/30/11 06:05 PM
12/30/11 06:05 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Sorry should have read your post more closely... I looked for the hose before, it is available at a variety of places. Summit, JEGS, other online vendors, etc. Stuff is not exactly cheap.
The lines in the floor is an interesting idea... have to remember that one. I was just going to lay the hose on the floor and exit it out a single 3-4" hole in the door. Thinking a little swinging plate with a wing nut to keep it close when not it use.
383, Hemi 4-Speed, AlterKtion, D60
[Re: A/MP]
#1146930
12/31/11 11:39 AM
12/31/11 11:39 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Anytime you are exhausting gases, you must know the content of those gases. With a race engine, there is alot of unburned gasoline when the engine is cold. The spark on an open electric fan motor can ignite that unburned fuel and blow back into your shop. A 10'length of flex pipe will remove most of the exhaust. You should always have adequate ventilation at all times.
true, and maybe the solution, if possible, is to fit your HVAC system in the shop with a way to go "positive pressure" which forces air into the building so that your exhaust gasses get pushed out by the positive pressure?
sounds expensive though. if you can't find an explosion proof blower fan option for inside the pipe, then I'd just make sure there's very little restriction so that it can flow straight out, and let the engine push the fumes out.
**Photobucket sucks**
