71' Cuda Grille: Broken Piece to Repo #1146767
12/30/11 02:07 AM
12/30/11 02:07 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
My 71' Cuda grille:
Needs a piece put back on.
Fabricate a piece? Get lucky finding one?
Suggestions please on how to re-do.
Can a specialty plastic shop fab a piece?
Would prefer ideas on DIY vs. send out.
Re: 71' Cuda Grille: Broken Piece to Repo [Re: Topcat] #1146768
12/30/11 11:41 AM
12/30/11 11:41 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
It's junk wrap it up I'll take it LOL. That is a common and easy repair. Find the piece and have it repaired.
logan426
Re: 71' Cuda Grille: Broken Piece to Repo [Re: Topcat] #1146769
12/30/11 02:01 PM
12/30/11 02:01 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 71' Cuda Grille: Broken Piece to Repo [Re: Topcat] #1146770
12/30/11 08:29 PM
12/30/11 08:29 PM
P
PaddleOn Offline
PaddleOn  Offline
P
you can get some flat abs sheet, then make patterns, heat, cut, bend, shape, weld. that was the first generation method of repair when i was doing them commercaally if/when i could not find good used ones...
Then, I went to a 3d scanned cad file and had them 3d printed, not cheap, but saved time... so at shop rate it was about a wash, but made a lot better repair.
