Re: magnum injection parts to LA heads
[Re: dusterbd13]
#1146739
12/30/11 03:17 AM
12/30/11 03:17 AM
RapidRobert
If there's enough material to drill the M1 at the diff LA angle it'd work. Rather than using the gaskets for a template I would mockup the intake with the gaskets and use the head bolt hole location (on the V slope) for an exact point. Not visualizing how at the moment but that'd be my thinking. Might have to mark their location at the front/rear of the heads' intake faces
[Re: RapidRobert]
#1146740
12/30/11 08:34 AM
12/30/11 08:34 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IIRC Mopar Perf has a manifold that fits the EFI and the LA heads. what are you going to do about knock sensor, cam sensor ect. ????
I am truckless..
[Re: dusterbd13]
#1146742
12/30/11 12:07 PM
12/30/11 12:07 PM
Posts: 4,323 NY NY
340duster340
NY NY
I used to have a vanity plate on my duster that read dusterbd! But no one could figure it out.
Anyways, I have a complete engine harness computer and fuse block from 1992 dodge Dakota with mag 318 ...pm me if your interested.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#1146743
12/30/11 12:15 PM
12/30/11 12:15 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
EDELBROCK # 28155
369.95 @ Summit.
I am truckless..
[Re: 340SHORTY]
#1146744
12/30/11 12:30 PM
12/30/11 12:30 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
are you looking to use the factory EFI system, or just need an EFI intake for the injectors, but running aftermarket/standalone EFI?
if it's the factory system, you'll be WAY ahead if you just went to the junk yards and picked up a 5.9L Magnum. much fewer headaches than trying to retrofit the magnum EFI to an LA motor.
however, if it's someone elses EFI and you just want the intake for the injectors, I'd look to *shudders* ebay, for the airgap style dual plane intake that's drilled for BOTH LA and Magnum intake patterns, it also has little bosses on it that can be drilled out for adding injectors. It's a carb intake, but only costs about $200 shipped, and you can get a 4bbl to 2bbl TB adapter plate for the factory magnum TB. (lots of guys are using those adapter plates with no issues, because a 4bbl M1 EFI intake is a lot cheaper than a 2bbl M1 EFI intake)
I have an adapter if you want it.
the factory TB in fully stock form is probably good to about 375-400 hp. I THINK that's whats holding me back right now on my build. I only put 285 hp to the wheels, and my AFRs indicate that I'm running out of airflow in the higher RPM. the stock magnum heads should flow enough for about 400 hp, but I'm guessing I'm around 360-370 hp.
but, you can also pick up a factory TB that's been ported to 52mm for about $200, and they can support up to 500 hp from what I've seen from guys with 408s in Dakota's with them.
**Photobucket sucks**
[Re: 70Cuda383]
#1146745
12/30/11 12:41 PM
12/30/11 12:41 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
his 2 posts tells what he is doing
I am truckless..
[Re: 70Cuda383]
#1146746
12/30/11 01:26 PM
12/30/11 01:26 PM
Posts: 257 albemarle, NC
dusterbd13
albemarle, NC
have any links to these intakes done like this? i currently have one, which is why i thought of going this route with modifying a magnum intake to use on my LA.
Michael
[Re: 340SHORTY]
#1146747
12/30/11 01:36 PM
12/30/11 01:36 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
EDELBROCK # 28155 369.95 @ Summit.
Don't forget you also need the fuel rails, #3641. Add another $106 for those.
Also have to consider what throttle body to use since most factory ones will not bolt to a standard 4150 bolt pattern. If budget is not the primary concern this is a good way to go. Have this set up for my 340.
To answer your other question: Stock Magnum TB is 635 CFM and should support 300HP at the crank. 19lb/hr injectors at 43.5psi rail pressure is about 270HP at .5 BSFC.
[Re: herkamer]
#1146748
12/31/11 11:25 AM
12/31/11 11:25 AM
70Cuda383
Marysville, O-H-I-O
I think that number is conservative. there's no way my entire drivetrain is only consuming 15 hp. I put 285 to the wheels on a stock magnum TB, indicating my combo is up around 350-375 hp.
anyway, here's the dual pattern intakes, and you can see where the intake runners have raised pads on them that COULD be drilled for injectors if needed.
http://www.ebay.com/itm/SB-Mopar-340-360...=item19c9171043
then with a 4bbl to 2bbl adapter like the one pictured in my attachment, you can bolt a standard stock TB onto the intake, or even an aftermarket larger TB or ported TB.
by the way, let me know if you want the adapter plate pictured. I don't need it
[Re: dusterbd13]
#1146750
01/01/12 01:16 PM
01/01/12 01:16 PM
70Cuda383
Marysville, O-H-I-O
I'm not really sure what the tall bosses are for. The could be cut off I'm sure. As far as height, it's really not any taller than an M1 thats cast as a 2bbl to begin with, which fits under the truck hoods easy, even allows for a 3" tall round air filter element. If you're doing this in a car, I don't know how it'll do on a car application.
[Re: dusterbd13]
#1146751
02/07/12 01:20 AM
02/07/12 01:20 AM
dusterbd13
albemarle, NC
so ive made up my mind on a few things. 1. using stock magnum fuel rails, with 30lb injectors running returnless style with 60PSI regulated pressure. 2. drilling and welding my victor jr for efi application 3. using a GM ECM and all related engine managemnt parts 4. using a magnum style throttle body. will get it running off the one i have, and upgrade when necessary. 5. hiding it all under an oval air cleaner. to that end, heres what ive been doing. got a fresher ECM (7727 interchange) 5.9 magnum throttle body 5.9 magnum fuel rails (and installed my free 30lb injectors) lean burn dist and the parts o convert it to GM HEI style computer control, new oil pressure switch question. does anyone have a source for an AN adapter version of this fitting? prefferably in a 90* format? michael
[Re: Andrewh]
#1146753
02/07/12 12:48 PM
02/07/12 12:48 PM
dogdays
You can get some ideas from James at www.bigblockranger.com, it'll show you how to install the injectors. BTW, I don't think there's anything wrong with your original idea as long as you take care of some of the beer barrel's weak points. First, the runners are long for torque but they restrict airflow and Hughes has been shortening them with good results. Second, the plate that seals off the bottom of the beer barrel (you take it off to modify the runners) leaks easily and that seal has to be improved, can't remember how they do it. I'd fill up the intake bolt holes with JB weld and use an intake gasket and transfer punch to mark the location of the center of the holes you want, then drill them. If you had a drill press that'd be easier once you got it set up, but a hand drill will work. Seems to me that starting with a working unit would be easier than trying to fabricate the first time. R.
