Big car brake options #1146459
12/29/11 05:02 PM
12/29/11 05:02 PM
Sullivan, Ohio
Max Wedge Savoy Offline OP
Sullivan, Ohio
I'm considering a front brake kit for my 63 and I am wondering what you folks are running? I like the wilwood dynalite drag kit but it says its for cars up to 2800 lbs. My car will be in the 3100-3200 lbs ball park. It will be a strip only car.
Re: Big car brake options [Re: Max Wedge Savoy] #1146460
12/29/11 05:34 PM
12/29/11 05:34 PM
AndyF Offline
AndyF  Offline
If you are running a 15 inch wheel then you can use a factory 11.75 rotor with lightweight Wilwood calipers. That is the setup that I designed 10 years ago and it has worked out for a lot of people since then.
Re: Big car brake options [Re: AndyF] #1146461
12/29/11 05:53 PM
12/29/11 05:53 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i run a wilwood kit on the front and rear stops me at 150+ and i dont have the heavy rotors.
Re: Big car brake options [Re: Max Wedge Savoy] #1146462
12/29/11 06:02 PM
12/29/11 06:02 PM
Az
Crizila Offline
Crizila  Offline
Az
IMO, stick with the all drum brakes that came with the car. Less drag than any disc set up. Plenty of brakes for two/three stops in a row without brake fade. No sense in going with more front end stopping power when you will be putting 3" wide front tires on it.
Fastest 300
Re: Big car brake options [Re: Crizila] #1146463
12/29/11 06:09 PM
12/29/11 06:09 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I have Aerospace's street HD setup and like it. Stops my 3800# sled from 140+ mph.
I had the factory 4 wheel drums when I was running mid 10s at 128-129 mph and would not recommend it. They'll stop decent, but get on them just a little too hard and they'd fade. They'd glaze over often too. Best thing I did was replace them w/ discs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Big car brake options [Re: an8sec70cuda] #1146464
12/29/11 06:25 PM
12/29/11 06:25 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i have been using the ww HD vented on all 4 w/4piston calipers for over 10yrs on my 3900# car and just upgraded to a hydraulic E-brake with 2 more calipers[4piston] in the back.
Re: Big car brake options [Re: AndyF] #1146465
12/29/11 07:49 PM
12/29/11 07:49 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
OOOoooooooo... Where do I score some of those cool calipers? I used the "disc-o-tech" article and converted my car to the 79'ish magnum front brakes. Will those Wilwood calipers fit my spindles?
Re: Big car brake options [Re: AndyF] #1146466
12/29/11 08:01 PM
12/29/11 08:01 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
andy does the kit you made use the factory 11.75 caliper adapters or one that you made up? the reasion i ask is i want to convert my big block 73 dodge dart. from the factory disc brakes to the
11.75 but so far have not found any of the factory caliper adapters. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Big car brake options [Re: gsmopar] #1146467
12/29/11 09:20 PM
12/29/11 09:20 PM
AndyF Offline
AndyF  Offline
Yes, that Wilwood kit will fit any of the 1973 or newer Mopar knuckles. (A, B, E, FMJ body cars)
You can get the caliper adapters, calipers, pads, hoses, etc from Mancini Racing or DoctorDiff.com. The kit is AR000 (my part number).
Re: Big car brake options [Re: AndyF] #1146468
12/29/11 10:40 PM
12/29/11 10:40 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Mine weighs 3905, and for thirty five years I raced it with drum brakes...after a few passes they would fade pretty good.
I bought the Jegs kit, using all factory stuff, it costs about $350 with everything, just bolt it on and go.
It is easily the best thing I've ever done to the car in the forty three years I've owned it.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Big car brake options [Re: Steve1118] #1146469
12/30/11 07:42 AM
12/30/11 07:42 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
What kit was it ? A front disc setup ?
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Big car brake options [Re: 65dragnet] #1146470
12/30/11 08:42 AM
12/30/11 08:42 AM
Sullivan, Ohio
Sullivan, Ohio
Thanks for all the input. I am trying to avoid running disc on the rear. I used a drum setup on my old 63. I had a front wheel cylinder fail in the bleach box. That was enough to make me lose my lunch. It was only running mid 11's though. This car should run mid to low 10's (I hope).
I too am curious about what kit you got at Jegs.
Re: Big car brake options [Re: Max Wedge Savoy] #1146471
12/30/11 10:39 AM
12/30/11 10:39 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run factory later mopar stuff on my 65 Belvedere.Its about 3600.Stops great at 120 with no problems.I run ceramic pads.My kid runs the 12 inch drums on his 62 300.It stops as good as disc and never fades.He only runs about 103 in the 1/4 though.Rocky
Chrysler Firepower
Re: Big car brake options [Re: therocks] #1146472
12/30/11 12:58 PM
12/30/11 12:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the standard Willwood stuff. Vented rotors on the front solid on the rear. I even saved them off my 63 Polara to use on my 64 Belvedere. My Volare runs the standard Chrysler factory disc and 10" drums. Stops fine from 122 mph.
Doug
Re: Big car brake options [Re: Max Wedge Savoy] #1146473
12/30/11 02:57 PM
12/30/11 02:57 PM
AndyF Offline
AndyF  Offline
I covered a ton of disc brake kits in my B body book. There are a bunch of pictures in there so you can compare different kits.
http://www.amazon.com/B-Body-Performance-Upgrades-1962-79-Design/dp/1934709301
