1970 charger hood w/hood pins: was it a factory option? #1146365
12/29/11 01:20 PM
12/29/11 01:20 PM
ne ohio
garymendy Offline OP
ne ohio
was a hood pin hood a factory option in 1970 and how would you be able to tell if a 70 hood with pins is a factory hood pin hood.
any info would be very much appreciated!!
i fell like someone is going to go there anyway, so: how many hoods could a hood pin hood if a hood pin could hood pins???
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: garymendy] #1146366
12/29/11 02:06 PM
12/29/11 02:06 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Yes, it was a factory option in 1970 (my Charger has it) - code J45 on the fender tag.
about 34% of all Charger R/Ts had the option - not rare but not very common either. No numbers on the Charger 500s (not available on XH base models as far as I know).
Info take from 1970chargerregistry.com
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: DGS] #1146367
12/29/11 02:10 PM
12/29/11 02:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My XH has then now
Coming soon!!!!
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: Mr.Yuck] #1146368
12/29/11 03:32 PM
12/29/11 03:32 PM
ne ohio
ne ohio
My XH has then now
very very sharp!!
does this mean that if it was a factory option that it had four hood pin holes or just the two in the front..
if it was four, that would make it easy as mine only has the two in the front???
thanks
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: garymendy] #1146369
12/29/11 03:43 PM
12/29/11 03:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Just the front 2 would be factory. This is a "pin on" hood. I do not have hood hinges anymore.
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: Mr.Yuck] #1146370
12/29/11 06:28 PM
12/29/11 06:28 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
My XH has then now
I want your hood
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: Pyper70] #1146371
12/29/11 08:37 PM
12/29/11 08:37 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
I only have 2 hood pins, but then again I only have half a hood.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: garymendy] #1146372
12/29/11 10:13 PM
12/29/11 10:13 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
The 70 Dodge data book is not clear regarding hood pin availability. In one section (shown below) it says "available on Charger R/T". In another section it shows them available on all three models.
Re: 1970 charger hood w/hood pins: was it a factory option? [Re: moparfan53] #1146373
12/29/11 10:16 PM
12/29/11 10:16 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is the other page showing J45 on all three models.
