a-body k member ? #1146090
12/28/11 10:23 PM
12/28/11 10:23 PM
Tennessee
CUDASCOTT Offline OP
Tennessee
whats the differece between a small block spool type k member
and big block direct connect spool type k member
thanks for the help
Re: a-body k member ? [Re: CUDASCOTT] #1146091
12/28/11 11:00 PM
12/28/11 11:00 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The drivers motor mount is 3/4" farther forward, I can't remember about the passenger side.
JB Rhinehart, Realist
A-Body's RULE!
Re: a-body k member ? [Re: Rhinodart] #1146092
12/29/11 01:18 AM
12/29/11 01:18 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The driver side is 1-3/16" back and the passenger side is 13/16" back. Easy to make your own. Check out the tech pages at Big Block Dart.
Re: a-body k member ? [Re: Jim_Lusk] #1146093
12/29/11 02:03 AM
12/29/11 02:03 AM
NY NY
3
340duster340 Offline
NY NY
yup you can make your own if you have a spare spool k-frame laying around.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: a-body k member ? [Re: Jim_Lusk] #1146094
12/29/11 11:52 AM
12/29/11 11:52 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Thanks Jim, it has been so long since I did it I must have drank those brain cells away! I remember now that I didn't worry about 1/16" and just did the passenger side 3/4" and the drivers side 1-1/4"....
A-Body's RULE!
Re: a-body k member ? [Re: Rhinodart] #1146095
12/29/11 12:22 PM
12/29/11 12:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The was how I made the first ones, but the fit wasn't quite right.
Re: a-body k member ? [Re: Jim_Lusk] #1146096
01/01/12 11:55 PM
01/01/12 11:55 PM
Tennessee
Tennessee
Thanks for your help guys, I just finisned making my first BB k member and the fit was perfect! Jim Lusk your the man!
Re: a-body k member ? [Re: 340duster340] #1146097
01/02/12 06:13 PM
01/02/12 06:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You don't need a spare , saw it off and slide it back , the thickness of the saw blade when making the cut is not a worry .
