Engine install from bottom? #114550
09/03/08 02:00 PM
09/03/08 02:00 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Please post how you installed your engine from the bottom without a lift? I will install my engine on the K frame in my E body but am curious on what is the best way to do this. Any input appreciated. Pics would be great!
Re: Engine install from bottom? [Re: PJM] #114551
09/03/08 03:04 PM
09/03/08 03:04 PM
None
71rm23 Offline
71rm23  Offline
None
Check out:
www.uscartool.com
Talk to John. He might be a member here(not sure). There are pictures etc on what you need
Re: Engine install from bottom? [Re: PJM] #114552
09/03/08 03:11 PM
09/03/08 03:11 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
My goal is the same, though I've not actually done it yet.
My "plan" is to roll the engine/trans/k-frame assembly on my home-made dollies under the car and lower the car down onto the k-frame in the correct location, adjusting the dollies as necessary, to make the k-frame/frame rail bolt hold line up.
The car is support by jack stands now. The rear jack stands are located under/at the mounting locations for the front spring hangers. My spring hanger mount bulkheads are boxed, so they're stiffer, although I don't think it matters. The front jack stands are under the rails by the forward torque boxes. With the rear wheels removed, so that no weight is supported by the rear springs (which makes the front of the car more difficult to lift), I can actually lift the front of the car by the front bumper by hand (OK, both hands). Pretty easy to do since there's no engine or trans in. It would probably be even easier if I put a couple hundred pounds of dead weight in the trunk (say, a Homeowner's Association officer).
Anyway, the k-frame ears might not be high enough to pull this off, but I can always shim up the k-frame on the dolly with more 2x4s. Getting the front of the car up high enough to slide the whole thing under shouldn't be a problem as it's easily liftable by two guys and the rear valence is high enough off the floor it shouldn't hit.
A lot of guys make a rig to bolt to the front frame rails and lift the front with a hoist. I didn't want to go that route, since (1) I don't have the extra steel tubing laying around, (2) I can't weld, and (3) my front bumper was on already to make space for the engine/trans (no matter how big the garage is, there's always a "space" issue).
Additionally, a lot guys will completely assemble the k-frame; including the spindles/brakes. I needed to work on my brakes, so they're already installed. I'll just remove the rotors when the time comes, bolt it all up, then put the rotors/calipers back on. Even with the rotors on the front, I could still lift the front without too much trouble. I'll post a series of pics...
This first one is of the engine/k-frame dolly and trans dolly. The engine/k-frame dolly is actually a generic engine dolly (from Harbor or Jegs, I don't remember) with the uprights removed.
The dolly under the trans is a regular wheel dolly with 2x4s for leveling. All the weight is on the k-frame and under the trans, none on the pan, though it looks like it.
-Marq
Re: Engine install from bottom? [Re: MoparMarq] #114553
09/03/08 03:17 PM
09/03/08 03:17 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
This one is of the front of the dolly. It looks like the casters are attached to the 3/4" plywood, but they're part of a steel frame engine dolly. You could probably just as easily make a dolly out of 1" plywood and 4 casters. I had to taper the front so that it would fit between the outriggers of the engine hoist. Obviously needed the engine hoist to get the engine mounted on the k-frame in the first place. The k-frame has a small skid plate on it, so it won't rest level on the plywood without the 2x4s underneath. Didn't matter, though, as I needed the extra height anyway, so that the control arms, tie rods,and lower ball joints would sit above the engine hoist outriggers also.
Re: Engine install from bottom? [Re: MoparMarq] #114554
09/03/08 03:21 PM
09/03/08 03:21 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Side view of the k-frame and dolly...
You can more easily picture the control arm and tie rod clearance here.
Still have to get the headers, among other things...
Re: Engine install from bottom? [Re: MoparMarq] #114555
09/03/08 03:26 PM
09/03/08 03:26 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
You can see why a lot of guys put the brakes on first, then slide the whole thing together. Here, my brakes are on (and work, so far.) But I'll have to remove the calipers and rotors to put the suspension back together. The upside is that I won't have to crack open any brake lines to rebleed the brake system. The spindle is supported by the upper control arm and held in place by 2x4 pieces.
It's a static load, so I don't think it does the bushings any harm.
Re: Engine install from bottom? [Re: MoparMarq] #114556
09/03/08 03:28 PM
09/03/08 03:28 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Great pics. I have already made a dolly also very similar to yours. I was just wondering how high I have to get the car to roll it under without a lift. Thanks
Re: Engine install from bottom? [Re: PJM] #114557
09/03/08 03:33 PM
09/03/08 03:33 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Nice setup! Love the 5 speed! Are you lowering the car from jack stands?
Re: Engine install from bottom? [Re: MoparMarq] #114558
09/03/08 03:34 PM
09/03/08 03:34 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
The location of the rear jack stands.
A B-body probably has more of a rear overhang than an E-body, so you might need to put some weight in the trunk to use this method.
It's not perfectly clear in the pic, but the upward edges of the cradle of the jack stand are fore/aft rather than sideways to (theoretically) prevent the car from sliding off the jack stands when it gets tilted up.
Re: Engine install from bottom? [Re: MoparMarq] #114559
09/03/08 03:47 PM
09/03/08 03:47 PM
Az
69hemibeep Online content
69hemibeep  Online Content
Az
I was going to remove the wheels from my rotisserie so I could roll the motor over the center bar and use the rotisserie as a lift. But now I have access to a lift.
1969 Hemi Roadrunner 2nd owner
Re: Engine install from bottom? [Re: PJM] #114560
09/03/08 03:59 PM
09/03/08 03:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've done it three times now.I set the oil pan on the dolly that way the K can move a little hanging by the motor mounts, makes it easier to line up the K bolts. After it's bolted in and sitting on jack stands, I install the spindles and lower control arms.
Look Mom, no front wheels or jack stands!
This time I did it sitting on a creeper with the back wheels on the ground.
Re: Engine install from bottom? [Re: 71rm23] #114561
09/03/08 04:17 PM
09/03/08 04:17 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Check out:
www.uscartool.com
I have my engine and trans on the K frame dolly (uscartool). I plan to plop my /6 with trans on it after the hemi goes in from the bottom.
Re: Engine install from bottom? [Re: Finoke] #114562
09/03/08 04:18 PM
09/03/08 04:18 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
another pic
Re: Engine install from bottom? [Re: Finoke] #114563
09/03/08 04:19 PM
09/03/08 04:19 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
last one..
Re: Engine install from bottom? [Re: Challenger 1] #114564
09/03/08 04:48 PM
09/03/08 04:48 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Wow! I never thought to use a engine hoist to the front. That looks like the easiest solution. Thanks!
Re: Engine install from bottom? [Re: PJM] #114565
09/03/08 05:14 PM
09/03/08 05:14 PM
Cincinnati, Ohio
Cincinnati, Ohio
I don't think this type of hoist is up to the job, I'd rent one like my blue one.
I always liked this shot, it's the first time I did it. I did'nt have a dolly handy but I had a home made creeper. So I used it and it was no problem other than the creeper and wheels were overloaded. Not having the dolly under my K made it easy to put a floor jack under the K when I was done to lift the car. The K is not bolted in in this shot but you can see how easy it is to install the bolts.
Re: Engine install from bottom? [Re: Challenger 1] #114566
09/03/08 06:12 PM
09/03/08 06:12 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Check out these guys...
http://inlandempire.craigslist.org/pts/800930434.html
Looks like a perfect setup for this - price is right!
'71 SSP - SOLD!
Re: Engine install from bottom? [Re: Mobarge] #114567
09/03/08 06:18 PM
09/03/08 06:18 PM
Cincinnati, Ohio
Cincinnati, Ohio
Looks like a lot of welding and material. Then alot of gismos sitting around in the way when your done with it.
Re: Engine install from bottom? [Re: Challenger 1] #114568
09/03/08 07:59 PM
09/03/08 07:59 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
For $350, I'd go for it!
'71 SSP - SOLD!
