Street 451 overkill???? #1145363
12/27/11 08:45 PM
12/27/11 08:45 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I was planning on building a pretty mild 451 for street use only. I have access to some 400 heavy main blocks. Any reason not to use one of these blocks? Do they sell for much more than a standard 400 block? I hate to use one, if they are in demand for race engines. Give me your opinion. TIA
Re: Street 451 overkill???? [Re: farmboy] #1145364
12/27/11 08:48 PM
12/27/11 08:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Use it I don't see them bring much more then a 400.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Street 451 overkill???? [Re: 1967dartgt] #1145365
12/27/11 08:51 PM
12/27/11 08:51 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
451's are nasty. My dad built one for a guy that drives it on the street and races it. He drives it to the track and runs 10.70s.
Re: Street 451 overkill???? [Re: farmboy] #1145366
12/27/11 08:57 PM
12/27/11 08:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they are the 230(I believe thats the number) blocks
some guys will pay a good price for them... for a
mild street engine, use any good 400 block
Re: Street 451 overkill???? [Re: MR_P_BODY] #1145367
12/27/11 08:59 PM
12/27/11 08:59 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Yes, they are 230 blocks.
Re: Street 451 overkill???? [Re: farmboy] #1145368
12/27/11 10:26 PM
12/27/11 10:26 PM
The "230" blocks came both ways, thick and standard mains.I have one of the thick ones and two that are not Only some of the first castings made bewteen 07-71 and 10-71, I think, where the cold weather thick main web blocks In other words not all the early "230" castings where the better thick main web ones
Re: Street 451 overkill???? [Re: Cab_Burge] #1145369
12/27/11 10:35 PM
12/27/11 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He did say thick web Blocks
Re: Street 451 overkill???? [Re: Cab_Burge] #1145370
12/28/11 12:14 AM
12/28/11 12:14 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I will check them tommorrow, I know a couple of them had the heavy main web.
Re: Street 451 overkill???? [Re: farmboy] #1145371
12/28/11 02:08 AM
12/28/11 02:08 AM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
Those 4 blocks that were sold were the good ones, thats why I had saved them. One of them that was sand blased did not have the original caps, but I don't know what Brad told you. I'de do the 470 with some real aftermarket heads that flow in the 350cfm range. Steve
Engine by DeTar http://www.kansasbadman.com
Re: Street 451 overkill???? [Re: CH3NO2] #1145372
12/28/11 07:04 AM
12/28/11 07:04 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Thanks Steve, I thought they were the good ones.
Re: Street 451 overkill???? [Re: farmboy] #1145373
12/28/11 07:59 AM
12/28/11 07:59 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Before sinking ANY money in the machining have cylinder bores sonic checked. I've got a standard bore 230 block 7-31-71 casting date. One cylinder is only .080 thick. 4 cylinders are real thin. Dave
Re: Street 451 overkill???? [Re: quickd100] #1145374
12/28/11 04:25 PM
12/28/11 04:25 PM
Been there done that, put money into a 400 block that was thin, didn't have it sonic tested first It split a cylinder wall on the dyno
