Prime over 80 grit? #1145142
12/27/11 04:36 PM
12/27/11 04:36 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Doing a scuff and shoot paint job on the race car. I have block sanded the original paint with 80 grit. My plan is to spray epoxy primer, then complete filler work and finally spray 2K primer prior to paint.
Question is should I apply the epoxy over block sanded paint with 80 grit? I was thinking that block sanding the 2K would take care of any scrathes showing through the epoxy.
Re: Prime over 80 grit? [Re: VITC_GTX] #1145143
12/27/11 05:56 PM
12/27/11 05:56 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Bare metal would be okay. Older paint I'd sand to at least 180. Most primer is designed not to shrink and show sanding scratches, but 80 is coarse! If the undercoat is decent, consider it another chance to block for smoothness!
http://www.autobody101.com/forums/viewtopic.php?f=5&t=16568&start=0
Re: Prime over 80 grit? [Re: RodStRace] #1145144
12/27/11 05:58 PM
12/27/11 05:58 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
i agree 180 or 220, you will sand thru primer and 2k to remove 80 grit marks
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Prime over 80 grit? [Re: VITC_GTX] #1145145
12/27/11 06:16 PM
12/27/11 06:16 PM
IOWA
Duster75 Offline
Duster75  Offline
IOWA
filler over bare metal only finish everything out with atleast 220 grit then prime with a 2k. Epoxy for what reason?? Just throughing $$$$ out the window.... I.M.O
Trucks/cars there all MOPARS 98 w2500 cummins24v5spd 85 w350 crew/short360 78 w150 shortfact.440 with upgrades 87 w150 soon to be new snowfighter 75 duster.... project since1999... never to be completed
Re: Prime over 80 grit? [Re: VITC_GTX] #1145146
12/28/11 12:30 AM
12/28/11 12:30 AM
Jacksonville Florida
elitecustombody Offline
180 or 220,if you want it to look good,80 grit scratches may show in paint after a while.
Re: Prime over 80 grit? [Re: elitecustombody] #1145147
12/29/11 02:11 AM
12/29/11 02:11 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I will hit it again with 180.
Thanks everyone.
Re: Prime over 80 grit? [Re: VITC_GTX] #1145148
12/29/11 02:18 AM
12/29/11 02:18 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
easy way to fix that mess is 220 3m wet sand paper, then a little 320 wet sand then prime
MOPAR OR NO CAR
Re: Prime over 80 grit? [Re: hemigod426] #1145149
12/29/11 02:24 AM
12/29/11 02:24 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The p-sheets for the primers you're using will recommend a grit. And it won't be 80 grit. Go too coarse and it will show through into the paint, and you don't want that. I've seen that done and it looks like hell!
